Re: MuuMuu's 68 Dart... It's a Learning Process...
[Re: DynoDave]
#1267379
09/28/12 11:04 PM
09/28/12 11:04 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I'm not sure we can confirm the application of those parts specifically to your vehicle (these links go right to the part #, without the year/make/model/options info a parts counter guy would need to order you the RIGHT parts). But it looks like you've got the right idea.
The jack and stands look like nice pieces.
I figured shortly after I posted that. I ordered the MC, rear wheel cylinders, and the last radiator hose I needed. I am 90% sure I ordered all of the right parts. So hopefully I can get to work next weekend and getting this running safely. So plan for next weekend is getting brakes up to par, changing hoses, and possibly flushing the radiator.
[Re: wally426ci]
#1267381
10/01/12 10:34 PM
10/01/12 10:34 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
It sounds like maybe your high beams are on. Hit the foot switch and that red light should go off. People will probably sstop giving you the finger at night also.
I don't know what you're talking about. The car hasn't left the garage since the accident. And the headlights haven't been on. Now which foot switch is this? I believe there is a manual pump on the floor for the windshield washer fluid reservoir (has been cut by previous owner so no worky). I'll check when I have the time. Will be at school late most of this week.
[Re: MuuMuu101]
#1267382
10/02/12 07:46 PM
10/02/12 07:46 PM
Triple Threat
Renton Washington
On the floor next to the kick panel by your left foot. Its a round button, tap that with your foot.
[Re: Triple Threat]
#1267383
10/02/12 08:23 PM
10/02/12 08:23 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Ok, so that's what it is. Then how would I use the wiper fluid reservoir (not that it matters since the lines have been cut).
And a little update. I'm off to pick up my jack and stands and a package arrived at my house earlier today. I believe the MC and my hose came in. I think the wheel cylinders won't come in till Thursday. So I most likely won't be making the cruise with the Dart since I'll be at school today and Wednesday till midnight.
[Re: MuuMuu101]
#1267384
10/03/12 04:32 PM
10/03/12 04:32 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
So right before I left for school this morning I quickly opened my package to make sure what I got. I opened the box holding the MC and I'm a little perplexed... Did my ignorance cause me to order another wrong part? Anyways, I just checked rockauto to make sure I ordered the right MC and I got the only kit that was for front disc, rear drums, and power brakes. The MC on there now only has 2 mounting points where the one I received has 4. Now going through rockauto I looked at all the MC's (manual/power) and all of them have 4 mounting points (stupid me for not checking). I was in a hurry this morning, so I didn't take too much time looking into it. Any or insight out there please? Pictures... Original MC still on the car... Looks like it should mount where the brake booster would go... This is the MC I ordered (A-1 CARDONE Part # 101326): http://www.cardone.com/Products/Product-Detail?productId=101326&p=rockHowever, it looks like the manual MC (A-1 CARDONE Part # 101326M): http://www.cardone.com/Products/Product-Detail?productId=101326M&p=rockBesides that I got my last hose and my wheel cylinders should come in tomorrow. I got Autospecialty / Kelsey Haynes 15/16" wheel cylinders so they should fit on my car. Besides that I'm not too bumbed out. I can work on hoses, fluids, and cleaning up the grease under the front end this weekend if I need to get another MC. Thanks for all your insight and help! Btw, I turned off the high beams this morning. Edit: So apparently I don't have a Dodge Dart booster or MC (thanks for pointing that out autoxcuda! ). Man these mods that the previous owners have done are killing me. Anyways, I forgot to mention I picked up my jack and stands yesterday from Lowes. The only one that had them was the one by my work. If you haven't noticed, I'm a little tired/sleepy and have been at school till midnight for the past couple nights (tonight as well). I probably won't be able to work on the car till Friday night.
[Re: MuuMuu101]
#1267387
10/06/12 06:29 PM
10/06/12 06:29 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Well I was finally able to do 1 thing on this car. Sorta like killing one stone with 2 birds. Due to my issues with the wheel cylinders I thought it would be a good idea to head on down to the front of the car and work in the engine bay a little. I said to myself, "Hey, you bought a fuel filter 2-3 months ago, why not put that on?" I replied, "Sure! Let me watch a youtube video on how to." Hmmmmmmmmn. Youtube video said some fuel may come out due to back-pressure from the pump. No worries, it should be fine. So I take off the fuel filter and as I expected fuel came out, but then what I realized is that really really smart engineering guy (previous owners) who had the car before decided to wire the alternator right by the fuel filter and now some fuel got into the little "protective" tube he put around it. That other super smart and devilously handsome engineering guy (now I'm talking about myself) didn't take the proper precautions and think enough before he did. Well, from what I learned in school is that when you have ignition + a source, you get fire. So I kinda don't want to start the car right now. Anyways, I think I may have found out I have a leaky fuel pump as well (I just tightened the fuel lines going to the fuel filter so we'll see what happens). There are also plenty of other leaks all around the car I'm trying to find. If you can't tell, I'm a wee bit frustrated. It doesn't seem like I'm going to make this safe enough to get it to Fall Fling this year. And the worst part about it is when I told my dad about Fall Fling, he got excited and said, "You're uncle is flying in the day before from Lebanon (first time in America), I'm sure he'd love to go! We should all go together." This death trap may very well be my coffin... And every post needs a picture... Yes, there's fuel all over the intake manifold (don't know if that's safe) and inside that pink "tubing" mabober which contains wires.
[Re: NV69B7RR]
#1267389
10/06/12 07:06 PM
10/06/12 07:06 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Way to keep plugging along!
Thanks. I'm going to flush the radiator, replace the upper and lower radiator hose, and replace the bypass hose (may even possibly by a proper battery tie down because all that's there is a bungee chord) on Thursday or Friday. With regards to the fuel pump link, I think I just loosened the lines when putting on the fuel filter. It doesn't seem to be leaking anymore.
As for now, I really need to get on my homework and get ready for one of my friends 21st Birthday parties. My friend with the Demon is going to be there so I'm going to ask him if he could help me out next weekend since I know he's got more tools than I do and he's done the brakes on his car.
[Re: NV69B7RR]
#1267391
10/06/12 07:15 PM
10/06/12 07:15 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Dont forget to bench bleed the master cylinder first.
Of course!
The car sitting as of a couple seconds ago. I did a little photo editing due to boredom.
[Re: MuuMuu101]
#1267393
10/11/12 01:43 AM
10/11/12 01:43 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Did a little work on the car today. My uncle (mom's side, not the one from Lebanon) came in tonight because he's catching an early flight tomorrow and we're closer to the airport. A little background on my uncle, he came in to the US when he was a teenager and has currently been doing body work for the past 50+ years. Well, I showed him the car for the first time, I'm not going to lie but I was kind of excited. He helped me align the door better so now it closes nicer and doesn't squeak. Then he saw everything else (from paint, to the steering shaft, to AC, to windows, and all that) and he basically told me to fix the brakes and then sell the car or not to put any more money into it.
He really didn't like the rust and didn't believe it was a CA car. He just thinks it's too much work and stuff. I'm a little bugged and pissed off right now because I have school and work to deal with. It kind of sucks to have your Uncle's disapproval. After a while he started to realize I was getting bugged and said, "Well, at least you're learning." I get he's looking out for my best interest and doesn't want me to go bankrupt, but still.
The plan as of now is replace radiator hoses and flush the radiator on Friday. Saturday I hope to replace the MC so I could maybe just go to Fall Fling with the car. If not I'll just take my other uncle in my Scion.
Sorry, I just needed to vent. A little discouraged.
[Re: MuuMuu101]
#1267394
10/11/12 08:25 PM
10/11/12 08:25 PM
moparpollack
Lil Herman
Lil Herman
85086
Does your uncle have any classic cars? Don't get discouraged he probably is old and doesn't have the energy of youth like your have.
[Re: moparpollack]
#1267395
10/11/12 10:37 PM
10/11/12 10:37 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Not really. His oldest car currently is a '87 Celica. He used to have other older Toyotas (usually 80's cars). But he's had a couple VW Beetles in his day as well and he has been doing body work for a long time.
[Re: MuuMuu101]
#1267397
10/13/12 03:30 AM
10/13/12 03:30 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
You're getting a lot farther on yours than I am on mine. I stop by the storage unit and start it, sometimes even drive it out of the unit. Had a guy come and look at it and drove it down the road. Seems like the master cylinder just dried out the rear seal and emptied its contents. The part that has fluid seems to work fine. Lol. Once I get me moved tomorrow, and get a friends Durango straightened out, I will get back to work on it. Or sell it and buy a California Bee...
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: OhioMopar]
#1267398
10/13/12 03:42 AM
10/13/12 03:42 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Nah, I've hardly done anything to the car. So far I've only fixed what's broke. This will probably be the most work and biggest fix on the car. Hopefully we'll be able to fix it so I can take it to the Fall Fling. It seems his Demon is up and running again too. I'll have to ask him if it's driveable enough to make it to the Fling as well.
