Page 3 of 5 1 2 3 4 5
Re: NOT HAPPY [Re: MR_P_BODY] #1264037
07/11/12 05:08 PM
07/11/12 05:08 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
We all jump the gun sometimes and get bit just part of the game I guess. You`ll get it sorted out and be on the road in no time.
Re: NOT HAPPY [Re: MR_P_BODY] #1264038
07/13/12 12:47 PM
07/13/12 12:47 PM
MR_P_BODY Offline OP
Well so far I havent found the smoking gun(no pun intended)...
I have the engine on the stand, all the exhaust ports
are oil saturated, pulled the intake and it was sealing
fine and all the intake runner are clean... I pulled
the rockers and the hold downs(TD rockers) so I
have to remove the hold downs to get to the head
bolts...will pull the heads next
Re: NOT HAPPY [Re: MR_P_BODY] #1264039
07/13/12 12:49 PM
07/13/12 12:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Valve stem seals maybe? Did you grind through em when porting? Just ideas............
Re: NOT HAPPY [Re: Thumperdart] #1264040
07/13/12 12:51 PM
07/13/12 12:51 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
oil would be in the port at that point - no?
what was done in the honing process? Plateau?
Re: NOT HAPPY [Re: DJVCuda] #1264041
07/13/12 12:56 PM
07/13/12 12:56 PM
I had the block bushed a few years ago and honed
with plates... it sat for a few years so all I did was
run a ball deglazer in it real quick then cleaned it
and started the normal assm work
Re: NOT HAPPY [Re: DJVCuda] #1264042
07/13/12 12:58 PM
07/13/12 12:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thinking maybe ex. porting cut through............If the ring seal went south maybe?...........I know some don`t run ex. valve stem seals...........
Re: NOT HAPPY [Re: Thumperdart] #1264043
07/13/12 01:04 PM
07/13/12 01:04 PM
oregon
greendart408 Offline
oregon
Mr P, do you have holes drilled in the heads for oil drainback in the valve spring area? Or slots ground in them so the oil will drain?
Re: NOT HAPPY [Re: greendart408] #1264044
07/13/12 01:20 PM
07/13/12 01:20 PM
Yes... each spring pocket is cut to drain oil....
Dom I ran seals on all the valves
Re: NOT HAPPY [Re: MR_P_BODY] #1264045
07/13/12 01:24 PM
07/13/12 01:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m not the best at this stuff so hopefully you find it.............
Re: NOT HAPPY [Re: Thumperdart] #1264046
07/13/12 01:28 PM
07/13/12 01:28 PM
LOL.... I guess I'm not either... otherwise I wouldnt
be in this spot.... breaks over.. I'll pull the heads
Re: NOT HAPPY [Re: MR_P_BODY] #1264047
07/13/12 01:37 PM
07/13/12 01:37 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
What heads are you running? Mabe the second ring was installed upside down? Just a guess. My eddy heads were ported into the rocker hold down bolt holes and it pulled oil in the cylinder past the hold down bolts.I replaced the bolts with studs and lock tite them into place and no more smoke but I had oil getting into the intake manifold. Hope you find the problem!
Re: NOT HAPPY [Re: WheelsUp73] #1264048
07/13/12 03:37 PM
07/13/12 03:37 PM
W-5 heads..... I'm calling it wasted out rings...
there is almost no cross hatch left in the bores...
they look shiney... the bit of oil thats on the pistons
and exhaust valve(some on the intakes but not near
as much) is sticky and can be wiped right off with
a paper towel
Re: NOT HAPPY [Re: MR_P_BODY] #1264049
07/13/12 05:42 PM
07/13/12 05:42 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Wasted, or Washed from fuel?
WOW, that didnt take long for those to do that. I guess [Edited by Moparts - Family Friendly Site - Keep it clean] happends and the bad rings are still better than windows in the pan.
Re: NOT HAPPY [Re: Moparnut426] #1264050
07/13/12 06:35 PM
07/13/12 06:35 PM
Yes... wasted and washed out... all the above and
all I can think of is they were washed due to a heavy
amount of fuel... tomorrow I'm going out to Milan
with Randy(labrat) so it can sit till Sunday... I
have the pan off so I'll pull the pistons Sunday...
order parts on Monday
Re: NOT HAPPY [Re: MR_P_BODY] #1264051
07/13/12 06:50 PM
07/13/12 06:50 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
not happy...
Three pages and no one said which dwarf are you?!
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: NOT HAPPY [Re: BBLM23] #1264052
07/13/12 06:53 PM
07/13/12 06:53 PM
not happy...
Is there a dwarf named stupid... that would be me
Re: NOT HAPPY [Re: MR_P_BODY] #1264053
07/13/12 07:02 PM
07/13/12 07:02 PM
Moparnut426 Offline
Moparnut426  Offline
not happy...
I wouldnt call ya stupid, but I think there is a Dopy,
LOL sorry, could be a little below the belt.
Re: NOT HAPPY [Re: Moparnut426] #1264054
07/13/12 07:07 PM
07/13/12 07:07 PM
not happy...
Thats close enough...lol
Re: NOT HAPPY [Re: MR_P_BODY] #1264055
07/13/12 08:07 PM
07/13/12 08:07 PM
NY,Poughkeepsie
87MO DAK Offline
87MO DAK  Offline
NY,Poughkeepsie
Don't feel bad ... I just went around the block with the hood pin's off.
Thrashed windshield ,cowl,and fiberglass hood .. I was just washing it
and forgot about the pins ...live and learn .
Re: NOT HAPPY [Re: MR_P_BODY] #1264056
07/13/12 08:10 PM
07/13/12 08:10 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
not happy...
I'm lazy.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
