Page 1 of 5 1 2 3 4 5
NOT HAPPY #1263997
07/08/12 12:14 PM
07/08/12 12:14 PM
MR_P_BODY Offline OP
I'm not happy with the engine in the Rampage... I
pulled the plugs today and see some oil on a few
but its also dog fat.. I cant find my compression gauge
(I think I loaned it out but cant remember) but I
will do a leak down today... it has a couple of oil
leaks that I need to address... one of them is the timing
cover at the pan/block.. plus I need to pull the oil
pan to fix a tiny crack at the corner where I screwed
up and lifted the back with the floor jack(stupid me)...
but if I dont like what I see on a few test I'll pull
the engine/trans today..... I just need to figure
out where the oil in the cyls is coming from....
BUMMER........ ok... rant off
Re: NOT HAPPY [Re: MR_P_BODY] #1263998
07/08/12 12:36 PM
07/08/12 12:36 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Fingers crossed that its something simple and cheap to fix.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: NOT HAPPY [Re: DusterDave] #1263999
07/08/12 12:45 PM
07/08/12 12:45 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
wet cyl walls...
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: NOT HAPPY [Re: cheapstreetdustr] #1264000
07/08/12 12:54 PM
07/08/12 12:54 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If I remember correct Mike the most of the smoke was coming from the right bank when you reved it a little in front of the garage door but both were hazing some blue.
Re: NOT HAPPY [Re: MR_P_BODY] #1264001
07/08/12 01:42 PM
07/08/12 01:42 PM
Az
Crizila Offline
Crizila  Offline
Az
Step at a time and don't go to the worst case scenerio right away. Test as much as you can first to narrow done the posibilities.
Fastest 300
Re: NOT HAPPY [Re: dartman366] #1264002
07/08/12 01:54 PM
07/08/12 01:54 PM
Most of that smoke in front of the shop was from
a oil leak getting sucked in at the ball socket on
the exhaust joint... I fixed that and 90% of the smoke
is gone but the plugs show a bit of oil and soot
from fuel and oil.... I'm starting with a leak down
then I'll pull the intake... if its farther in than
that I'll pull the engine
Re: NOT HAPPY [Re: MR_P_BODY] #1264003
07/08/12 02:25 PM
07/08/12 02:25 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Gotcha'
Re: NOT HAPPY [Re: dartman366] #1264004
07/08/12 02:39 PM
07/08/12 02:39 PM
Not good... looks like the rings are junk.... I did
leak down on 2 cyls.... one was 40% leak the other
was 60%..... engines gotta come out... I can only think
that they got fuel soaked... but it fired up instantly...
I can hear the air dumping into the crank case
Oh well.... do-do happens... this is my FIRST engine
that I ever had to tear back down... I'm pissed at
myself
Re: NOT HAPPY [Re: MR_P_BODY] #1264005
07/08/12 02:52 PM
07/08/12 02:52 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Without re-reading your thread,,,was this a recent build or one that has been setting for awhile?
If you like drag racing, support your local track.
Re: NOT HAPPY [Re: MR_P_BODY] #1264006
07/08/12 02:53 PM
07/08/12 02:53 PM
Louisiana
Red440 Offline
Red440  Offline
Louisiana
that sucks sorry for ya buddy, hope it goes smooth the rest of the way, that is one sweet ride
Re: NOT HAPPY [Re: CHAPPER] #1264007
07/08/12 03:03 PM
07/08/12 03:03 PM
Its was fresh.... but sat a couple of months but I
primed it a few times while turning it over... I
think this time its going on the dyno
Re: NOT HAPPY [Re: MR_P_BODY] #1264008
07/08/12 03:11 PM
07/08/12 03:11 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
New pistons or used?? What I am getting at, is, are the ring lands/grooves posibly too wide from past use?
Re: NOT HAPPY [Re: CHAPPER] #1264009
07/08/12 03:27 PM
07/08/12 03:27 PM
New pistons, rings, bearings, rods, crank all that
stuff was new
Re: NOT HAPPY [Re: MR_P_BODY] #1264010
07/08/12 03:28 PM
07/08/12 03:28 PM
Az
Crizila Offline
Crizila  Offline
Az
myself
Fuel soaked is a good probability - and it's one of the reasons I don't use WD40 on my piston /ring installs. Too easy to wash off if you are on the rich side or the motor doesn't fire right away.
Fastest 300
Re: NOT HAPPY [Re: MR_P_BODY] #1264011
07/08/12 03:32 PM
07/08/12 03:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
stuff was new
I`d lean it out and go beat on it for a few and see if the sealing improves............done it before w/non detergent oil and it worked but maybe yours has different issues.........
Re: NOT HAPPY [Re: Thumperdart] #1264012
07/08/12 03:38 PM
07/08/12 03:38 PM
stuff was new
I'm gonna put the rockers back on and lean it out
and try... sure cant hurt anything now
Re: NOT HAPPY [Re: MR_P_BODY] #1264013
07/08/12 03:48 PM
07/08/12 03:48 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
stuff was new
The W5 434 we just put together was using oil a bit. We did a couple WOT pulls on the engine dyno, and it sealed up. Like you say, it's worth a try!
-Kenny
Re: NOT HAPPY [Re: MR_P_BODY] #1264014
07/08/12 03:50 PM
07/08/12 03:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
stuff was new
Can`t hurt.............
Re: NOT HAPPY [Re: StrokerAspen] #1264015
07/08/12 03:58 PM
07/08/12 03:58 PM
stuff was new
-Kenny
I;ll lean it out and try loading it on the brakes...
if it works... great, if not.... it comes out
Re: NOT HAPPY [Re: MR_P_BODY] #1264016
07/08/12 04:06 PM
07/08/12 04:06 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Make sure the crankcase can breathe.
Leaking timing cover makes me wonder. Is it leaking or being pushed out with crankcase pressure?
