1970 340 exhaust manifold question #1263481
07/07/12 02:34 PM
07/07/12 02:34 PM
california santa clarita
moparpete22 Offline OP
hi,
just purchased the bolt kit to install my 340 hi po exhaust manifolds and have 4 studs and 4 short bolts. not sure where they go. it could be all studs or all short bolts and work. i figured out the other ones (commons sense) just not sure exactly where these ones go.
also kit comes with dish style washers and not exactly sure which way i should install them. iam thinking the dished part on the outside.
thanks for your help
Re: 1970 340 exhaust manifold question [Re: moparpete22] #1263482
07/07/12 03:07 PM
07/07/12 03:07 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Stud at each end.
Concave side of washers to manifold.
Re: 1970 340 exhaust manifold question [Re: moparpete22] #1263483
07/07/12 03:09 PM
07/07/12 03:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The studs go in the end bolt holes as they go into water, 2 per head, the dished washers go on after the manifold goes on, obviously, and the dish part is toward the manifold.
Put some type of sealer on the studs before you screw them into the heads.
tree'd by barry
Re: 1970 340 exhaust manifold question [Re: Alaskan_TA] #1263484
07/07/12 05:55 PM
07/07/12 05:55 PM
great. thank you very much. i appreciate it.
Re: 1970 340 exhaust manifold question [Re: JohnRR] #1263485
07/07/12 05:56 PM
07/07/12 05:56 PM
hi, thanks for the info. thanks for mentioning the sealer. i would have forgot and had a mess later. so busy trying to figure out where the hardware went forgot about the water ports.
Re: 1970 340 exhaust manifold question [Re: moparpete22] #1263486
07/09/12 01:25 AM
07/09/12 01:25 AM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
You should have gotten 6 studs. 2 more for the long nuts to attach to on the passenger side.
Re: 1970 340 exhaust manifold question [Re: moparpete22] #1263487
07/09/12 08:18 AM
07/09/12 08:18 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
