Re: TTI headers in a A body with 426 HEMI & Price
[Re: 71fliptop]
#1259660
01/08/14 02:04 AM
01/08/14 02:04 AM
Posts: 995 Addison,IL
OUTLAWSSAA
Addison,IL
The real issue in an "A" Body is that I have found (with Stage V heads) the you have to channel / box the Frame rails. There is no way you could modify the headers as you are fresh out of room. That was the task I was hoping to avoid.
I have noticed on other "A" bodys that the same thing has been done - sometimes the frame rail has been formed into a triangle cross section for more clearance.....
"No room" is an understatement. I have Stage V millenium heads, which come only in a raised port design. The headers are stepped from 2 1/4 to 2 1/2. I've had them on the car for 6yrs, and its still a battle every spring putting them on. It takes 2 guys and you better remember the proper sequence or your in for a long day. BTW the frame rails are not channeled.
[Re: OUTLAWSSAA]
#1259662
01/09/14 08:49 AM
01/09/14 08:49 AM
71fliptop
Outlaw, very interesting. What make of Headers and are they still in production? Is the Engine in the "Correct" (as per TTI instruction) position - also, did you find you had to move it back too? Some "underskirt" pictures would be really great, thanks!!!! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 71fliptop]
#1259663
01/11/14 01:22 AM
01/11/14 01:22 AM
OUTLAWSSAA
Addison,IL
Fliptop, the headers were custom built. As far as the motor location, I'm using a stock crossmember and trans mount, so front to back its probably correct. I never measured the height, but I think it sits higher than normal if I had to guess. LMAO, if I were to show you "underskirt" photos you would never put a hemi in an A body. With That being said, if you had a smaller cubic inch motor where you could use a 2 1/8 or 2 1/4 header it would be much better. That's why I have to laugh when somebody starts a rant about putting a diaper on one of these things. Its never going to happen. GOOD LUCK!
