I have found out through experience that magazine articles often leave vital info out so here is my first hand with some pics. Before I started I wanted to get as many of the parts together as I could. I liked the March power steering pump so I decided that would be waht I would use, of course If I was gaonna put a nice chrome power steering pump on I needed to just go ahead and dress the engine while I was at it. I bought a new chrome alternator and the march brackets. I had to replace the front pulley to a double serpentine belt system so I bought that. I went ahead and installed this on the engine.Here is a before and after of the engine.
Before After Nother view The radiator hose looked bad so I put a new chrome hose on there. Now for that power steering. Removing the Manual steering box is pretty easy. I went down to Autozone and rented their Pitman removal tool, came home unbolted the pitman arm after I aligned the front wheels to dead straight and pulled the pitman arm.
Not much room underneath. It will swing outta the way. Next I unbolted the steering column and let it drop down. When I installed the quick ratio unit I also installed the flaming river universal joint in place of the Mopar piece. You simply unbolt it and then ease the steering wheel back to remove it from the connection. This coupler completely eliminates any slop in the steering and is a breeze to work with.
Manual universal coupler You will have to unplug all the wires to the steering column so I just yanked it and layed it on the workbench. Next unbolt the steering box and it will work out pretty easy. Now to put in the power steering box. This is the stage two box from firm feel. Here is a side by side of the two boxs.
Side by side You can see the power steering box is BIGGER. Heres some pics of trying to wiggle it in.
From the front From the top Engine coming up I have Dougs 2" headers on the car and there was no room. I unbolted the drivers side engine mount and jacked the engine up (a lot) probably as far as it would go. The steering box barely fit in, but it did. I I then bolted the box in and let the engine back down. The steering box just barely touchs the number 5 cylinder header and I will put a dimple in there some time. The pitman arm is the same for the power box and the manual box on a 72 so I just bolted it up. The pitman arm is keyed so you cannot screw it up unless you try real hard. I did not know the power steering spline for the steering column was smaller till I went to reninstall the steering column. A quick call to flaming river and they had exactly what I needed.
Steering couple installed The steering column for a power steering box is about 2.5 inches shorter than for a manual. The steering column is collapsable thats why it has that funky looking collar below the steering wheel. I've always figured if I have a wreck and hit the steering wheel hard enogh to collapse it I am going to be hurting big time so I wear my seat belt and don't want to test it out. The nylon pins that are in the column gave up the ghost years ago so I collapsed the column enough to line it up. I spent a lot of time detailing my steering column there was no way I was going to replace it for a power steering column. The new Flaming river universal coupler replace the manual one perfectly and I bolted everything back up. I couldn't find a nice steel braided pressure line so I went to Autozone and got a new one. They make several for the car and it took two trips to get the right one. I had some Russel steel braided line I could use for the return line, and I did. Installing the pressure line it looks funky, too many bends but it bends kinda easy so I just bent it till it laid down and looked neat.
Steering lines. Some people have talked about how the March pump gets hot and the fluid foams up so I bought a powwer steering cooler and installed it while I was about it.
Pump lines and cooler After checking all the lines connections, steering column is mounted, tight and plugged in, I fired it up. I had already put about half a quart of Valvoline power steering fluid in it and let it set for a day to kinda leak down and prime the pump and power box. After firing it up I added the rest of the quart while turning the wheel full left and right. It took about a quart and a half to top it off. Now My wife, son and I have fallin in love with the car again. Steers just as nice as my Lexus. If you want to change from power to manual all the info you need is here. Check the E Body parts from time to time all the stuff I removed will show up there. Good luck.
