Re: 498 cid 440 stroker build formula
[Re: torqueaddict]
#1258642
06/28/12 04:41 PM
06/28/12 04:41 PM
Posts: 959 france
jose jones
france
In 1996 I built my first 496 from a 440 block, 4.15 crank, eagle H-beam rods,wiseco pistons with a 10.1 compression ratio and B&B lightweight wrist pins (155 grams)instead of about 235 for other pins. The cam was a hydralic 540 something lift Comp cam,Holley 850 DP, I had Mopar Performance stage 1 heads with a set of stamped steel rocker arms and a Carter high volume fuel pump. 6 quart Hemi oil pan,high volume MP oil pump, with 3 inch full exhaust,I drove it a bunch on the street and at the track it ran 11.7 @117 MPH on pump gas and never broke in 15 years of abuse, it also would rev like a 340. I would suggest on your motor Harland Sharp rockers and Indy ported SR-295 Heads they work great and flow good numbers, a light rotating assembly is the key, the guy that now owns the motor is still running it today, I went to the finals racing it at Mopars at the Strip and the semi finals at the Mopar Nationals it was even features in Car Craft in Mar 2003 I have also built 572 stroker motors this 496 is your best bang for the buck, the car ran great on super unleaded it is a red 69 Road Runner with a 727 2500 stall converter 354 gears in a Dana 60
[Re: BIG-MIKE-500 ci]
#1258644
06/28/12 05:29 PM
06/28/12 05:29 PM
Posts: 4,046 Minnesota
72blubird
Minnesota
Sorry op not trying to hijack thread. Reason I asked about vacuum is I am building 470ci 400 block stealth heads 440 source .035 stroker kit. hoping vacuum will be enough hearing your combo is encouraging. Also you said it was a four speed what rpm did you leave the line at?
I will also be at close to 4000lbs with driver using 3.23 gears and a 4 speed. using Comp Cams Xtreme Energy High Lift XE285HL hydraulic flat tappet camAdvertised Duration .285 int .297 ex/Dur @.050; .241 in .247 ex/ Lift .545 in. 545 ex with 1.5 rockers. Lobe Separation Angle 110.
What was I thinking....
[Re: torqueaddict]
#1258650
06/29/12 10:26 AM
06/29/12 10:26 AM
Posts: 42 Nelson-New Zealand
BIG-MIKE-500 ci
Nelson-New Zealand
Anthony; I would suggest you opt for having your piston very close to flush with block deck. You "will" make some pretty high pressure with that cam, especially installed advanced 4 degrees. You will have a better/safer engine with a higher cylinder pressure,if quench is 40-45thou.(ie:Distance between closed chamber face & top of piston). If you go more than this I feel a slightly larger cam may be a safer option. Pump gas,with good matching of all parts, will support up to 200 lbs Compression. Get the quench wrong & you may need to drop 20 lbs.
#1258651
06/29/12 11:02 AM
06/29/12 11:02 AM
72blubird
Minnesota
Mike that 60 ft is very good. If I could be that consistent I will be thrilled. Your rpm is right where I was thinking. Had thoughts of trying 1500 but may try a bit lower. What kind of tires do you run? If I get through this and can still afford it I want to get a centerforce clutch have a mcleod now. My brother has a center force and loves it.
[Re: torqueaddict]
#1258652
06/30/12 10:42 AM
06/30/12 10:42 AM
Posts: 3,152 Central NC
gch
Central NC
Well guys this is the cam chose in this:Hydraulic. Hot Street cam, likes 2800 converter, Hi-Rise type dual plane intake with 850cfm carb, headers, 10:1 compression and 3.73 gears. Likes up to 200HP nitrous. • Advertised Duration (Int/Exh): 276/284 e • Duration @ .050 (Int/Exh): 234/242 • Gross Valve Lift (Int/Exh): .513/.533 • LSA/ICL: 110/106 • Valve Lash (Int/Exh): Hyd/Hyd • RPM Range: 2200-6400 • Includes:
This is slightly bigger than the big last one. I understand many people like big cam, I am just not one of those guys. I want my car to be a sleeper. I also have elected to send the pistons back to Hughes and get the dished pistons with a 13cc in the piston. This should put me at 10.5. I will be happy with that, I think I will enjoty this combo alot. I will have my local engine shop balance the kit using all needed parts. I have one question tho, can I use my 383 harmonic balancer or will I need one specifically for my 440? Thanks guys in advance.
As long as you have an internal balance 383 you can use the same balancer.
That cam will make a mean low end/mid range motor that will probably like to shift in the 5500rpm range. Think of a stock 440 magnum with headers and now add 100ft lbs.
