Re: Help with my new 340 build up
[Re: RobX4406]
#1257780
06/28/12 03:58 PM
06/28/12 03:58 PM
Posts: 1,178 Indy
FlyFish
Indy
...............Weight, 40 pounds... REALLY? This is the ONLY place the OOTB ede has an advantage for the OP's engine. How much HP does it take to overcome 40#? ......
If the 40 lbs was on the rear of the car, it would not be a big deal, just add power...but 40 lbs off the nose IS a big deal. ![](/ubbthreads/images/graemlins/Twocents.gif)
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: RobX4406]
#1257781
06/28/12 04:11 PM
06/28/12 04:11 PM
Posts: 246 Jackson Michigan
67barrracuda
Jackson Michigan
Yes, this is a budget build and I wouldn't mind picking up a set of used heads.
Jackson Michigan
[Re: FlyFish]
#1257784
06/28/12 04:52 PM
06/28/12 04:52 PM
Posts: 2,141 junction city oregon
viperblue72
What about higher compression ratio tolerance of an aluminum head? If the price is comparable why wouldn't you go with aluminum?
[Re: Brian Hafliger]
#1257788
06/29/12 08:14 AM
06/29/12 08:14 AM
Posts: 2,128 sweden
sshemi
sweden
Brian, just out of curosity. What is th max flow you have got out of the RHS head and the Edelbrocks on your bench, both fully ported?
BTW, I lost 48 lbs going from fully ported J heads to fully ported Edelbrocks.
They will go 298cfm at .650 lift before backing up.
My vent 298 at 0,515 lift and then stalled. Ex had a nice curve all the way up. This is with 2.055 & 1.625 valves. But my intake doesnt match the ports because of poor fitment. Didnt have the time to get it machined.
It is a decent head with some issues and why the ..ll didnt they make them out of alu???
