Re: drilling TQ throttle plates? [Re: kilroy] #1256786
06/26/12 01:49 PM
06/26/12 01:49 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Hmm...good to know what sizing worked for you. I haven't gone quite that big...was a little worried.
I wish there was a way to run a channel into to secondaries base plate. Sort of a controlled air leak, say, adjustable with a air-bleed type jet. The other approach would be to crack the secondary throttle plates just a tiny wee amount to let some air in, but not initiate any of the secondary fuel system....easy to say, quite a bit more difficult to actually implement.
Re: drilling TQ throttle plates? [Re: Diplomat360] #1256787
06/26/12 02:24 PM
06/26/12 02:24 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I played around with this problem in the past on a stroker motor with a bigger cam.
1) Drilling throttle plates may lead to booster fuel dribble.
2) Cracking open secondaries could be difficult for a number of reasons but mainly because they are so big and it would need to be done almost to perfection.
What I did was take a tee off of the PCV hose and used different orifice sizes, it seemed to work well but I did not mess with it very long. You would want to have this extra orifice take in filtered air. I tried many orifice sizes and dont remeber what I ended up with but it was not small, (I think around 3/16 inch) You would want to use a wideband A/F device to iron out your system.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: drilling TQ throttle plates? [Re: Dave Watt] #1256788
06/26/12 09:13 PM
06/26/12 09:13 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
I'll be curious to hear your feedback on how the part throttle cruise is when driving down the road. It may need more primary jet or, the metering rod tree may need adjusted to compensate for the additional air being brought in by the primary throttle plate holes you drilled.
Ive already had to compensate for the extra air by opening the idle mixture screws by 1 to 1.5 turns (final tune is still out)
But I agree that the amount of fuel will probably need to be adjusted BUT I was think the opposite. More like since there is more fuel being supplied by the idle system that the rest of they system may need leaned down some, I was think by the metering rod tree. But I will definitely remember your suggestions and try them also.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: drilling TQ throttle plates? [Re: Rapid340] #1256789
06/26/12 09:17 PM
06/26/12 09:17 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
I couldnt figure out how to crack the secondaries as they seem to come to a rest on the base plate as a stop
I thought about drilling the secondaries to counter act the possible velocity on the booster causing dribble as you suggested but what worried me, along with cracking the secondaries, was the the timing of the air velocity/ fuel/ timed vacuum open created by air bleed in the plate.
Re: drilling TQ throttle plates? [Re: Diplomat360] #1256790
06/26/12 09:22 PM
06/26/12 09:22 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
The intriguing thing I though about doing, and I read this somewhere so I cant take any credit, was to drill below the air cleaner stud through the base plate and use some sort of adjustable orifice (jet or valve or something) this would exclude the secondary air systems and the possibility of booster drip also.
I wasnt even sure how a TQ would respond to drilling the blades so I didnt want to screw up something I could repair easy.
I think I will look more into this now.
Re: drilling TQ throttle plates? [Re: kilroy] #1256791
06/26/12 11:17 PM
06/26/12 11:17 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Not trying to start any arguements but I open up the low speed jet about .003 and adjust the initial timing to cure that problem. I've run cams at 274 to 292@.050 duration with thermoquads using these fixes. I DON'T drill the butterflys. Dave
Re: drilling TQ throttle plates? [Re: quickd100] #1256792
06/26/12 11:43 PM
06/26/12 11:43 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Not trying to start any arguements but I open up the low speed jet about .003 and adjust the initial timing to cure that problem. I've run cams at 274 to [Email]292@.050[/Email] duration with thermoquads using these fixes. I DON'T drill the butterflys. Dave
On that 605? or smaller motors? Just the bleed on top or the tube? Ive tried a some to a whole lot of intial and could not get what I was looking for so I settled on 19* intial. How about your transfer slot, were they in the square to normal range? Thanks for input.
Re: drilling TQ throttle plates? [Re: kilroy] #1256793
06/26/12 11:52 PM
06/26/12 11:52 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
First theres a tang for the secondary stop you can bend to adjust the amount the secondaries stay open. Its in the rebuild book. Theres also a set screw on top of the tree you can adjust.. I like to do that instead of cutting the spring. Thats just butcher work when you cut the spring. I understand there might be a vacuume issue but unless your idle vac is below 10Hg.. I wouldn't cut it. Theres a couple air bleeds under the tin covers one can also drill out. Bunch of things you can do to have a crisp, bog free Thermobog. As a last resort I'd drill the throttle plates, but the above usually gets everything running peachy. Oh.. and TQ's LOVE lots of initial timing.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: drilling TQ throttle plates? [Re: DARTH V8Я] #1256794
06/27/12 07:48 PM
06/27/12 07:48 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Im pretty sure this is the part your talking about, but this is just for wide open position, there is a roll pin that runs through the shaft thats part of the stop that hits the base plate, unless Im mistaken.
Its really hot here today and Im busy with work so Ill update this weekend about the drive and tune.
Re: drilling TQ throttle plates? ***UPDATE*** [Re: kilroy] #1256795
07/01/12 08:30 PM
07/01/12 08:30 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Ok, did some serious driving today. Im not advocating drilling blades for everyone, but as a last ditch, this worked excellent for me.
Settled on 9/64 holes drilled in both front plates on the away side of the throttle shaft from the transfer slots.
The idle is outstanding. 850rpms just over square on the transfer slots and excellent off idle movement no stumble bumble of farts while driving at any engine speed or driving attitudes and Im a stickler for stuff running without a hitch. After hot driving (its 95* and high high humidity) I was able to lean the mixture screws down to 2.5 turns, maybe able to get another 1/8 to 1/4 turn after driving some more. I have notice I think that overall Im slightly more rich (Im attributing this to the extra turn on the mixture screw) but I really dont know because I dont have an A/F meter (yet). Could just be the heat. I plan on leaning the system by a 1/4 turn on the metering rod tree and see what happens. I will let yall know more in a day or so.
Re: drilling TQ throttle plates? [Re: kilroy] #1256796
07/01/12 09:53 PM
07/01/12 09:53 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Where are the air bleeds on a TQ?
Great thread!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: drilling TQ throttle plates? [Re: Rug_Trucker] #1256797
07/01/12 09:56 PM
07/01/12 09:56 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Great thread!
The bleeds are under the little removable plates beside the meter rods on top of the top plate.
Re: drilling TQ throttle plates? [Re: kilroy] #1256798
07/01/12 11:24 PM
07/01/12 11:24 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
I also forgot to mention on my earlier that I have looked at my carb during idle and have seen no booster puller over since drilling my blades.
Re: drilling TQ throttle plates? [Re: kilroy] #1256799
07/02/12 11:50 AM
07/02/12 11:50 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
I might need to this with mine too. I'm running nearly 20* of initial timing, but it just won't idle high enough with a "square" slot exposed.
I have to go an extra 5 or so turns on the idle screw.
It runs and drives fine, but I can tell it's a little rich on the idle.
Re: drilling TQ throttle plates? [Re: 440newport] #1256800
08/01/12 11:59 PM
08/01/12 11:59 PM
Iowa State fan
kilroy Offline OP
kilroy  Offline OP
Iowa State fan
Just thought I d update some more. Im having no drivability issues with my car after doing this. Ive leaned my carb up with the metering tree as I said a little bit and I need to mess with my vacuum adv just a bit but my carb is great idles smells cleaner now that that Im off the transfer slots so much. NO intermittent drivability issue, or top end issues. Next step getting a/f meter to get killer tune on.
Again this is not fix all, it was just my last resort to get the idle slots down to "correct" after having a very aggressive tune on the distributor and a "big" @.050 street cam.
