Re: E-body 22" radiator installation...
[Re: jrwoodjoe]
#1256764
03/20/13 10:29 PM
03/20/13 10:29 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
This look ok? Got the fan and spacer in and threw it together prior to detailing...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: sbcjd]
#1256765
03/20/13 10:54 PM
03/20/13 10:54 PM
Posts: 75,423 A gulag near you.
JohnRR
A gulag near you.
Looking at your photos I wonder what shroud you are using and it appears the passengers side of the radiator has no shroud bracket. There should be fan shroud brackets on both sides of the 22 inch radiator. This makes me wonder if you are using the incorrect shroud. Just trying to help.
It's there , it is hiding under the overflow hose.
