Re: Dodge Stratus...so close but so far away
[Re: Bigcube]
#1256180
06/24/12 12:54 PM
06/24/12 12:54 PM
Posts: 916 SE Washington
Forest
SE Washington
X 2, nice job. Did you set up the chassis for a small block and a big block?
Big block will be easy swap and then minimal work to mount a powerglide behind it...
[Re: 340Cuda]
#1256184
06/24/12 01:51 PM
06/24/12 01:51 PM
Forest
SE Washington
Very nice! Keep us posted on the build and tell us about the engine. Bill
The motor is 408 in a R3 block and Indy 360-1 heads. Pretty mild combo that I used in my Dart.
Went 10.62 at 3,418 lbs, so Im hoping with some up-grades and a more areo 1,000lb ligter car it'll run ok for now...
[Re: Forest]
#1256187
06/25/12 07:25 AM
06/25/12 07:25 AM
Posts: 20,704 in a cattle trailer down by th...
Guitar Jones
Very nice! I love it.
[Re: DavidDean]
#1256191
06/25/12 12:39 PM
06/25/12 12:39 PM
Forest
SE Washington
VERY NICE!!!Maybe I missed the details but more info on the engine-trans would be nice
For now its is my 408 that I used to bracket race in my Dart.
Its a R3 block, 408, 13 to 1, .630" solid with Schebuck lifters, Indy 360-1's slightly touched up by Dwayne Porter, 950 HP. 727 w/ griner brake and a 8" PTC converter.
This motor ran 10.62 iun my 3,420 lb Dart with smaller TTI headers, and exhaust system, and no vacuum pump.
Im hoping in a more areo 1,000lb lighter car it will run ok untill I can do something like 540-572. When I do a real motor some day I will also put a powerglide behind it. The chassis is set up for the big block and will only need a slight re-work to the trans crossmeber for a powerglide.
Here is a few more shots of the car. The chassis is all 4130 chromoly and certified to 6.0 in the 1/4.
[Re: SCDaytona]
#1256195
06/26/12 10:04 AM
06/26/12 10:04 AM
Forest
SE Washington
Great Looking ride there. Looks like a lot of fun. Just curious, why all steel except for the hood?
Nobody makes parts for these cars...I guess because they make carbon/fiberglass bodies for Pro Stock?
Unless someone knows of a company that does I am unaware of anyone that makes parts for them.
Doors would be my best investment right now, they are about 40lb each after ALOT of work...
[Re: stevet340]
#1256198
06/26/12 01:08 PM
06/26/12 01:08 PM
Forest
SE Washington
Awesome build! Can you show pictures of how the chassis is mounted to the body? I always wondered how they mount them... Thanks
It may be hard to see but I bent hoops out of 3/8" & 1/2" chromoly tubing that rest in pinch welds etc. Then I welded them to the car body after it was mounted. I mounted the rocker panel to the rocker bar of the chassis in the same way...
