P4452993AC vs P4452993AE ? #1255655
06/22/12 02:37 PM
06/22/12 02:37 PM
Oklahoma City
Jwilli500 Offline OP
Oklahoma City
Mopar Performance lists P4452993AC which is the Hemi Grind Cam with Lifters. Jegs lists P4452993AE as cam only? Is this a mistake on Jegs part or is there really 2 different parts? Just to further muddy the waters, a search for P4452993AE shows it as a cam and lifters at other vendors. Zippy?
Re: P4452993AC vs P4452993AE ? [Re: Jwilli500] #1255656
06/22/12 03:06 PM
06/22/12 03:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The basic part number is always for the same product, the letters at the end just denote some minor change in the original part or the kit.
Generally speaking, Mopar always sells the cam and lifters as a kit, never the cam by itself.
Re: P4452993AC vs P4452993AE ? [Re: John_Kunkel] #1255657
06/22/12 03:53 PM
06/22/12 03:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Jegs and Summit do sell the cam without lifters as well as the complete kit.
Re: P4452993AC vs P4452993AE ? [Re: Jwilli500] #1255658
06/22/12 04:08 PM
06/22/12 04:08 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
J,
That's a mistake on Jeg's part.
Both are cam and lifter kits.
There are several differences between AC and AE, I could darn near write a book on that one topic, but it'd be better to hit the highlights....the main ones that make a difference are:
-on AE, purple paint was traded for an etched component number (which does not match the package number).
I usually washed the paint off with carb cleaner anyway.
So purple shafts are not purple anymore (don't anyone be freaked out), but 10 years from now the component number can be ID'd, so nobody will have to guess what it is.
-AC had Stanadyne lifters, AE has Johnson Hylift lifters,
a quality improvement. Lifters are still made in Michigan, just at a different place now.
-No more break in lube with AE. Within the next couple years the break in lube will be categorized as a type of hazmat, which is too big a can of worms to monkey with anymore. Things are not going to get any better in that regard....It was a proactive move.
-I sheet was extensively reworked on AE
There's more, but those are the big ones.
Cam is still ground in Michigan same as before, same grinder, packaged in MI also, same packager since 07/08-ish.
Rich H.
Esse Quam Videri
Re: P4452993AC vs P4452993AE ? [Re: ZIPPY] #1255659
06/23/12 01:51 AM
06/23/12 01:51 AM
Oklahoma City
Oklahoma City
Thanks for the responses guys! Rich, the info about the Johnson Hylift Lifters makes me feel better about it too! Went ahead and ordered it from Jegs as they're quite a bit cheaper plus its an opportunity to support a Mopar Pro Stock! LOL
Re: P4452993AC vs P4452993AE ? [Re: Jwilli500] #1255660
07/02/12 03:37 PM
07/02/12 03:37 PM
Oklahoma City
Oklahoma City
Just realized I hadn't followed up! Got the cam AND lifters from Jegs last week. Pretty good deal for $170. Thanks again for the spot-on info guys!
Re: P4452993AC vs P4452993AE ? [Re: Jwilli500] #1255661
07/03/12 09:35 AM
07/03/12 09:35 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good to hear
Rich H.
Esse Quam Videri
