Re: Anyone Use Extrude Hone for Exhaust Manifolds?
[Re: Silverbullet2]
#125491
11/17/08 09:41 PM
11/17/08 09:41 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
I think I picked up a total of 12HP on a "back to back" test. That was on a 12 to 1, 484 cubed Hemi.
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: 360view]
#125495
11/18/08 10:07 AM
11/18/08 10:07 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
if the post-Extrude Hone manifolds are still off the engine and available, perhaps it would be a good idea to make some templates of the port shapes the EH process created?
if these templates were then scanned and added to the archives, perhaps other factory manifold owners using a grinder could be very close to the gains found?
how do you get to the areas that you can't even SEE ??
the extrude hone process mostly SMOOTHES (polishes) the internal surface of the manifold .
[Re: RapidRobert]
#125497
11/18/08 12:51 PM
11/18/08 12:51 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Doug Dutra cast some new split /6 exhaust manifolds from scratch. For that kind of money a person could almost recast a set with a bigger ID. Just thinking out loud
Well, I don't know if that would work or not, but let's say for a minute that it would, if you can get a set of (outwardly accurate, internally larger) exhaust manifolds cast for $600.00 please sign me up!
[Re: ScottSmith_Harms]
#125500
11/18/08 01:27 PM
11/18/08 01:27 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
As far as Dudeks Hemi picking up 12HP, I have no doubt that he did, as I said above:
I think there is a limit to gains you can expect but IMO every engine will benifit differently from it. As I've said before, you chase the bottle necks in the combo, if the bottleneck is the manifolds it will make a bigger difference and push the bottle neck to some other area needing improvment to gain more HP.
His combo obviously needed more exhaust flow and the EH process helped his engine in that respect more than it helped mine.
True enough, but when you consider the power his FAST Hemi is making it's not that far off (percentage wise) as 5-6hp on a 400hp motor.
I'd be interested to see how the big block HP manifolds flow compared to your stock small block ones. After all at the same hp levels it's all about CFM, right? My guess is that on my 440-6 PS motor, I'd see even less of a gain than your 4-5hp.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
#125502
11/18/08 02:29 PM
11/18/08 02:29 PM
DPelletier
Could be Dave, pure guesswork at this point.
That's a fact. I think I'll spend the money on the best TTI system and quality mufflers. I'm ALMOST positive that will be money better spent.
I'm not knocking you or anyone else that wants every possible advantage. Actually in my case, extrude honing isn't PS legal anyways.
1974 'Cuda
