Chrome ECU ? is it or not? or buy HIREV 7500 #1253860
06/19/12 02:51 PM
06/19/12 02:51 PM
Connecticut
5126brl No more Offline OP
Connecticut
Is this a Chrome race ECU or just a factory ECU ?
No part numbers on it,has 4 pins,
Trying to get info. thinking it may be a 1978 red express truck box.
Chrysler decal looks odd for race unit?
Re: Chrome ECU ? is it or not? [Re: 5126brl No more] #1253861
06/19/12 03:57 PM
06/19/12 03:57 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
I don't see any picture attached, but the Mopar Race Chrome ECU has a black heat sink. A plain old low performance chrome ECU may have a blue or gold heat sink.
John
Re: Chrome ECU ? is it or not? [Re: DusterW2] #1253862
06/19/12 04:15 PM
06/19/12 04:15 PM
Connecticut
Connecticut
OH So a picture would make it easy! Thanks
Also trying to find out what I should have for voltage at the coil +
Re: Chrome ECU ? is it or not? [Re: 5126brl No more] #1253863
06/19/12 04:32 PM
06/19/12 04:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It looks like the chrome box unless its a knock off...
the voltage at the coil is reduced going through the
ballast... I dont recall the voltage off hand but I
think its 8 volt... maybe some one can answer that
Re: Chrome ECU ? is it or not? [Re: MR_P_BODY] #1253864
06/19/12 04:47 PM
06/19/12 04:47 PM
Connecticut
Connecticut
Thanks,
I have a .25 ohm ballast and have about 9 volts now
before had 1.5 ohm and had 6.3 volts.
Re: Chrome ECU ? is it or not? [Re: 5126brl No more] #1253865
06/19/12 04:54 PM
06/19/12 04:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks,
If I remember right the .25 ohm is for the gold box
but not sure if its needed for the chrome(I just dont
remember)
EDIT
Looking at my parts book its just needed if you run
the P3690560, P4876832, P4876833 coil... it will work
with any box other than the orange box and production box
Re: Chrome ECU ? is it or not? [Re: 5126brl No more] #1253866
06/19/12 05:38 PM
06/19/12 05:38 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
"Race" ECU's all had 5 pins with one not used.
I never saw one-chrome or gold with any decal on it.
Re: Chrome ECU ? is it or not? [Re: actionange] #1253867
06/19/12 05:48 PM
06/19/12 05:48 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
That is not the race box. It is a chrome replacement box.
JAKES AUTOMOTIVE
Re: Chrome ECU ? is it or not? [Re: JAKE68] #1253868
06/19/12 06:11 PM
06/19/12 06:11 PM
Connecticut
Connecticut
Wow! If it is a stock box it's been on there 30 years
I have gone 10.99 at 124 with that box!!
I could have been quicker with a race box!!
Re: Chrome ECU ? is it or not? [Re: actionange] #1253869
06/19/12 06:40 PM
06/19/12 06:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I forgot all about the 5 pins
Re: Chrome ECU ? is it or not? [Re: actionange] #1253870
06/19/12 07:47 PM
06/19/12 07:47 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Nope,....here is a MP chrome,FBO,and a Rev N Nator.
I have two chromes and two orange boxes that all have 4 pins. The harnesses all have 5 wires for the early 5 wire boxes but leave the 5th wire unattatched.
Keith
Re: Chrome ECU ? is it or not? [Re: 5126brl No more] #1253871
06/20/12 02:04 AM
06/20/12 02:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats cool but I have been 10.70's with the orange MP box. Ron
Re: Chrome ECU ? is it or not? [Re: Dunnuck Racing] #1253872
06/20/12 06:24 AM
06/20/12 06:24 AM
Truckville, the capital of NY
85_Ram_4speed Offline
I believe the 5-pin boxes were for prodution when they went to the dual side ballast. I had orange and gold boxes that were only 4-pin. Al my regular production boxes are 5-pin.
But as always with Ma Mopar, never say never--there always seems to be exceptions to the rules.
Outcast Dodge guy.
Re: Chrome ECU ? is it or not? [Re: Dunnuck Racing] #1253873
06/20/12 07:39 AM
06/20/12 07:39 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Keith
I think I see a dyno setup in the pic.
Did you do a comparison with the boxes? If you did, what did you find?
Re: Chrome ECU ? is it or not? [Re: 5126brl No more] #1253874
06/20/12 08:19 AM
06/20/12 08:19 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
As far as I can tell a ecu is an ecu. the one in my car has nothing at all on it to identify it. It goes to 7000 rpm no problem. Ive used many "stock" ecus with the same results.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Chrome ECU ? is it or not? [Re: BigBlockMopar] #1253875
06/20/12 08:34 AM
06/20/12 08:34 AM
NY usa
540challenger Offline
NY usa
Keith
He compared a few different systems I think his results start on page 3
https://board.moparts.org/ubbthreads/show...e=0#Post6927491
Re: Chrome ECU ? is it or not? [Re: 540challenger] #1253876
06/20/12 10:27 AM
06/20/12 10:27 AM
Northern Indiana
Northern Indiana
Yes, I have done tons of testing with several boxes.
The earlier made Orange box(before people had issues with them) runs pretty similar to the current Chrome boxes.
I have a few different stock replacement boxes,one that will pull high rpm's. But it gave up a bunch of power through the mid range.
When a engine reaches it torque peak,the cylinder pressure can make it really hard to light off a mixture. If the ignition is not strong enough,it loses power.
I ahve learned more about Mopar boxes than I ever thought I would want to know.
I used to run them on bracket cars and always thought if you had a decent spark and set your total timing,there was nothing to be gained. The more I learn,the more I realize that old theories are just that,old theroies.
Keith
Re: Chrome ECU ? is it or not? Hirev 7500 ? [Re: Dunnuck Racing] #1253877
06/20/12 04:19 PM
06/20/12 04:19 PM
Connecticut
Connecticut
So it looks like this may be a stock unit
Since I will need a new one what has anyone heard about HIREV7500 that RicH E. is selling on ebay?
Re: Chrome ECU ? is it or not? Hirev 7500 ? [Re: 5126brl No more] #1253878
06/20/12 10:04 PM
06/20/12 10:04 PM
Northern Indiana
Northern Indiana
I was just over on ebay looking at them. Not much info but they have a hirev and a hirev 7500. They look like a LX100 and LX101,respectively. That is purely heresay on my part,but several guys like the Standard ignition stuff.
Keith
Re: Chrome ECU ? is it or not? or buy HIREV 7500 [Re: 5126brl No more] #1253879
06/23/12 08:59 AM
06/23/12 08:59 AM
CT
440Kilmartin Offline
CT
Maybe if you put in MSD your car will go 9's
