Re: New Outlaw racecar arrived!
[Re: Georg]
#1253224
06/19/12 09:29 PM
06/19/12 09:29 PM
Posts: 4,421 in a chair
mopartony
in a chair
mopartony- I cant belive that aluminium headed small block would be so heavy and weight only 100lbs less than 500cid iron headed bigblock with two carbs...But I need to weight my motor to be sure
You and I are in the same boat. I was hoping it would be lighter. But it isn't. I might be able to get a pic of the tag, but it is in MI and I am in AZ and my stepdad just was at my house this morning before I saw this post. Or I would have had him get a pic of the tag.
Let me look through the ones i have and see if one is clear enough and I will post it.
[Re: mopartony]
#1253228
06/21/12 03:51 AM
06/21/12 03:51 AM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
Uoah...500 pounds is not what I expected to be honest. What weighting there so much? Heads are aluminium only block is iron and crank are quite tiny also...
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
[Re: Georg]
#1253229
06/21/12 07:18 AM
06/21/12 07:18 AM
Posts: 6,147 Melbourne , Australia
LA360
The heads are pretty big, as is the manifold and water manifold. The block is deep skirted with 6 bolt caps. When you think about it, you can see where the weight is. I was shocked liked anyone else though!
Alan Jones
