Runs bad after sitting 20-75+ minutes..
#1252202
06/16/12 09:19 PM
06/16/12 09:19 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Car is a '67 Dart, 440, eddy heads, Accel ignition, mighty demon carb, mechanical fuel pump. The car runs great most of the time. Cruises at about 190 degrees. But every time I leave it sitting for maybe 20 or more minutes, the engine is not running right when I start it. The temp isn't excessive when this is happening. When it's running rough after starting, it sounds weaker, and when I put it in gear or reverse, the RPMs drop way down. When I step on the gas it takes an extra push to get it to go, then as it decels again the RPMS drop and sometimes it just poops out. I restart it, rev it up, it sounds like it's running weak etc. Once I get out on the road (out of the parking lot) and I've gone a few hundred feet, it runs fine again. I think it's a carb issue, but can't figure out what would be going wrong with it. Any ideas? I've considered vapor lock, would that give these symptoms that resolve after driving a few hundred feet?
Re: Runs bad after sitting 20-75+ minutes..
[Re: Exit1965]
#1252204
06/16/12 10:01 PM
06/16/12 10:01 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Gasoline isn't formulated for carburators any more... The situation your describing is called heat soak... The engine is up to temp, you shut the engine down & heat rises & everything cooks (soaks up heat) the fuel isn't designed for sitting unpressurized, it doesn't have stabilizers to resist boiling... On a fuel injected vehicle all the fuel remains under pressure so it can't boil... After you car starts the fuel pump will begin to refill the fuel bowl(s) & the new fuel will be cooler helping mask the effects of heat soak....
[Re: DaytonaTurbo]
#1252207
06/17/12 08:34 AM
06/17/12 08:34 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I run an A/F sensor on my car and what is happening during the heat soak period is that the A/F guage shows super lean (16-17) during this time. When I startup after it has been setting, it will show 16-17 and I just keep feathering the carb until the A/F starts to come back down. thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: Exit1965]
#1252215
06/19/12 08:10 AM
06/19/12 08:10 AM
Posts: 531 Virginia
JimG
Virginia
I run a fairly common induction system... Performer RPM (Eddy heads, so no crossover heat) with a Holley. I'd been running an electric pump for years, with the fuel line routed away from the exhaust... up the firewall and approacing the carb from the rear of the engine. When E10 became the only fuel we could get in this part of the country, I began getting the same symptoms. I added a Moroso wooden carb spacer and a sheetmetal heat shield. That helped, but it still wasn't as good as it was with non-ethanol gasoline. The thing that fixed it for me was a vapor return line. Yes, it's a PITA because (in my case) there is not a fuel sending unit available with the return fitting already in it, so I had to fabricate one. I bought a 5/16" fuel line kit from Fine Lines that fit my car, and made slight modifications to it and used it for the return line to the tank. 1/4" is the "normal" size, but I wanted a pre-bent set that fit nicely, being too large won't hurt anything, and 5/16 is the smallest size they sell for my car. Of course, you could bend your own out of a roll of 1/4" tubing. If you go this route, be sure to add a 1/16" (approximately) restrictor in the return line. My advice, for what it's worth ( ), is to try all the stuff that's already been suggested, but be prepared add a vapor return line if the problem persists. J
[Re: Exit1965]
#1252218
06/21/12 08:17 AM
06/21/12 08:17 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
Got my 4 hole spacer today, 13.99 off ebay, and find out that the butterflies on the Mighty Demon do not clear it. I had a feeling it might be an issue.
So I'm going with an open spacer rather than fiddle with this thing. Will give the 4 hole to my dad.
What intake do you have ? Making the 4 hole fit might be the better thing to do.
[Re: JohnRR]
#1252219
06/21/12 09:07 AM
06/21/12 09:07 AM
Exit1965
Rancho Cordova, CA
It's a Performer RPM dual plane intake.
I thought the smaller the spacer height, the less the overall difference (in terms of performance) between 4 hole and open might be which is why I thought to just get the open spacer.
Right now it's hanging up on the secondary throttle blades when they start to open, once it gets past a certain sticky point it seems to be clear. It wouldn't seem to require much filing/sanding to clear.
So with a performer RPM, should I just file/sand this one to clear?
