Update. The Hemi is in
I removed both covers, but after it was bolted in we found out the pass side cover was on the inner fender as one of the earlier posters said. So we had to put it back on the cart and raise the body again to
it actually came out nice as we used a bfh and smoothed it with a die grinder. The car is black and our work dose not show. Thanks to all for the info on the install. As for the how tall question. We used a cart from us car tool. it had approx 4" wheels and the hemi with carbs on was about 42" high on the cart that's a guess on the higth. we done it in a garage with an 8' ceiling no problem. I hooked onto a bracket attached to bumper bracket area of the frame. we blocked the rear tires up about 12".
