Re: A hypothetical question for you all to chew on.
[Re: bwdst6]
#1251026
06/15/12 11:48 AM
06/15/12 11:48 AM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
My buddy has a gen 3 Hemi in his 69 Dart, 426cubs ported heads, different cam, 13 to 1 comp 904 tranny with a brake, dana 4.30 gears on a 10.5 tire, car weighs 3213lbs, he is still trying to get the fuel injection figured out and has spent alot of time on the dyno, but he has gone the fastest to date 9.67. Now that said it is dead rich in the upper RPM band. So I think there is alot more left in it. I would say low 9s. I know my next build will be a GEN 3 hemi, after I get the wifes gen2 hemi together.
[Re: HEMIFRED]
#1251032
06/15/12 09:47 PM
06/15/12 09:47 PM
Posts: 306 Mesa, AZ
cagebob1
Mesa, AZ
oh yea ? how about 4600 for a 426 gen 3 block
That's an aluminum block..how much for a Gen2 in aluminum?
[Re: hemidup]
#1251034
06/15/12 11:35 PM
06/15/12 11:35 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
The G3 weighs at least 200 lb less than the G2. You said cubic inch for cubic inch, which I take to mean no humongous elephant motor competing with a 430 inch G3.
30 years ago, a friend of mine ran a 433 bigblock chevy powered camaro into the 9s. I bet the latest Hemi heads flow better than the old rectangular ports, and the new "Hemi" chamber is much better than the bbchevy open chamber head which had to have a mountain range in the middle to get compression. That camaro weighed in at around 2950 lb. I don't think a 433 inch G3 Hemi would have any trouble laying waste to that car, meaning I can't see why you couldn't get into the 9s normally aspirated using a stock block. Now you could also do it with an elephant motor but the $$$ would indeed be more and you'd have more problems with weight transfer, engine fitment, etc. Just my
R.
Just for s n grins we weighed our Gen 3 Drag Pak motor and it came in at 460 lbs. Our Gen 2 426/484 stoker with K heads came in at 720 lbs. With the new Gen 3 aluminum block could put 468 cubes down to 370 lbs.
anyone know what a BB weighs with aluminum heads and intake?
my gen 3, not running yet
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: StrokerPost]
#1251036
06/15/12 11:51 PM
06/15/12 11:51 PM
Posts: 168 Washington State, USA
Winchester 73
I say Gen III. I obviously have a swayed opinion on the topic though. Can you have power adders? Tell me more what your class restriction are. I'm running a 6.1 with forged drop in pistons(stock forged crank stock powdered rods), ported heads, custom cam, TTi headers, and a Kenne Bell supercharger 10 lbs of boost. Making approximately 640 to the wheels. I'm at 3200 lbs as well. that puts me in the ball park of where you want to be. If I had better rods I could turn the wick up to 18-22 lbs and make so monster power, but my build was a so called budget build. I have close to 18 in the motor and power adder.
I know tons of guys running new Chargers, challengers, and 300 that are in the 10.5 range and they are 4400lbs. One of the guys is running it N/A alumin block 46X CI motor. The other are NO2 cars, etc. If it's a budget build just get a short block like my 6.1 port the heads, change the cam, and put the bottle on it and you will make ur number.
I chose to go supercharger b/c of the wow factor.
Ok I will clarify this a bit more. First, this IS purely hypothetical, nothing I will be doing..........at least anytime soon. No power adders here, just heads up, pure motor, cubic inch to cubic inch. One thing that appeals to me about the Gen 3 is the weight as compared to a Gen 2, also the size makes it a winner, but I'm still interested in the best over all performer in this comparison. I'm in no rush to do either cuz I know that every month that goes by the Gen 3 will have more and more available, but the possibilities are already impressive.
BTW, what is currently the largest displacement you can achieve with the Gen 3?
you cant really compare cubic inch to cubic inch and get a fair idea of which would be cheaper.the elephents advantage 500 plus ci stroker kits for under a grand.
[Re: dizuster]
#1251038
06/19/12 12:32 AM
06/19/12 12:32 AM
Posts: 928 NC
SLOW67
NC
Same reason every chevy guy in the world runs a LSX now instead of the old 454.
too bad Mopar hasn't supplied us with an affordable platform like the LS series......
[Re: SLOW67]
#1251039
06/19/12 09:32 AM
06/19/12 09:32 AM
Posts: 10,021 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Just from a weight stand point, the Gen 3 has about 250 lbs advantage from the get go, or roughly 10 percent. So to go 9.50s at 3200 lbs a gen 2 hemi would need about 725 Hp. To run with that combo, a gen 3 would only need 655. Part of that difference I came up with was the Gen 3 can use a 904, which saves power by itself. Add in the weight front/rear advantage, and for a dual purpose car it almost becomes a no brainer IF you don't care what the valve covers look like. Of course that is disregarding the issues of cost, which I don't have a clue on. For a purely race deal, I could see taking my full flow mechanical injection system off the big wedge and run methanol. That would save a ton in computor costs I think. I would love to see something done like that with a bone stock shortblock and purely bolt on parts to just see what could be done like the old days. When it blows up, go to the bone yard and pull another one out of a wrecked Chrysler!
