Joel, I am pretty sure everything is still square, it won't hurt to check next time it is up on the hoist though. The car drives straight down the track, so it should be pretty close. The diff is still located by the spring pin the way I have done it.
I documented a fair amount of the leaf link set up I have done under the car if you wanted to check it out. Here is the thread....
https://board.moparts.org/ubbthreads/show...&PHPSESSID=I am pleased with the first outing, it stuck to the ground great all things considered. I know there is more in this set up yet!
-Kenny
