Re: Delphi 600 Box
[Re: sublimehemi]
#1247750
06/13/12 05:34 AM
06/13/12 05:34 AM
Posts: 373 sandwich IL
sublimehemi
sandwich IL
ok just read you have to cut column..right
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: Delphi 600 Box
[Re: TC@HP2]
#1247752
06/13/12 10:58 AM
06/13/12 10:58 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Okay, so it has a somewhat faster ratio built in to it. That does simplify center link interference for some engine/header set ups compared to fast ratio arms. Other than that, what does it provide that you can't achieve with a Firm Feel box? Does it weigh 10 pounds less, does it have less drag, or what. Not sure if I'm too thrilled about the vibration reducing coupling offering either. That typically rings of reduced road feel. In what way does this unit deliver twice the value of the other offerings that are out there?
Fitment. (we hope) If you have an Abody with powersteering and want to install a newGen Hemi, it might mean the difference between just swapping steeringboxes, instead of having to install a rack&pinion system, or, go back to the prehistoric times and go with manual steering...
Re: Delphi 600 Box
[Re: BergmanAutoCraft]
#1247755
06/13/12 04:44 PM
06/13/12 04:44 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Honestly feel and ratio are good enough for me. Ever drive a modern car even without a rack? A LOT nicer than what we are stuck with.
The A body hemi is not known yet, but would be really nice if it does. I would not build an A body with a hemi just for this reason.
When are they going into production? Last I spoke with Borgeson, the boxes were on the back burner while they were making other parts. Seeing as I'm putting a hemi in an A Body, I'm interested.
Anyway, I'm just finishing up my headers that fit around the factory power steering box with my 5.7 hemi.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Delphi 600 Box
#1247757
07/04/12 10:47 AM
07/04/12 10:47 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I put one in my wife's C3 Corvette, it is a night and day difference! The car used to handle like a shopping cart with a bad wheel, now it steers like a modern car. Feel is great nice control on the highway, quick ratio in the corners. A well thought out bolt in deal. It's worth every penny.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
Re: Delphi 600 Box
[Re: Jim_Lusk]
#1247758
07/04/12 10:54 AM
07/04/12 10:54 AM
Posts: 296 Germany
1964Polara
Germany
We built a small sector police-type firm feel box for my son's Barracuda (all JY parts except for the seal kit) and it performed well.
I would be really interested to know more about this!!! Which parts (Numbers) did you use and where did you buy them?
Thanx
Re: Delphi 600 Box
[Re: 1964Polara]
#1247759
07/04/12 12:08 PM
07/04/12 12:08 PM
Posts: 18,686 Fresno, CA
Jim_Lusk
Fresno, CA
Thanx
I don't know. It's been over ten years, but the basics were a factory cop car box from an 80s Dippy and a factory A-body box with small sector. We took the cop box worm gear and valving and put that in the early box with a seal kit for the early box. The specs and rebuild procedure ar ein the FSM.
Re: Delphi 600 Box
[Re: PHJ426]
#1247763
07/08/12 10:39 PM
07/08/12 10:39 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Cant wait for an eval on it. Would love a side by side of it,a stock power and stock manual box for an idea of clearance.
Mopar to the bone!!!
Re: Delphi 600 Box
[Re: Uhcoog1]
#1247766
07/16/12 03:32 PM
07/16/12 03:32 PM
72Swinger
Nebraska
If I had the cabbage id order it right now, if it didnt fit it wouldnt be to hard to unload at this point.
Re: Delphi 600 Box
[Re: 72Swinger]
#1247767
07/16/12 07:50 PM
07/16/12 07:50 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
looks like the fittings are metric, add in new hoses or new fittings to the cost.
Re: Delphi 600 Box
#1247768
07/20/12 12:25 AM
07/20/12 12:25 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Ratio is key. On center it's got to be infinitely better than our beloved 21:1 dinosaur.
Hmmm. Every Mopar PS box, late '50s thru the last B-vans, T/A-AAR option included, is 15.7:1. Look it up.
Rick
Re: Delphi 600 Box
[Re: Rick_Ehrenberg]
#1247769
07/20/12 01:36 AM
07/20/12 01:36 AM
Jim_Lusk
Fresno, CA
Rick
Rick, quit with the facts, would ya? The steering ratio of the factory power box is exactly why my son's Barracuda got power steering after the first autocross. It wasn't the difficulty in turning the car, but I could see his hands FLYING in the corners with the manual.
I still don't see $800 in value with the Delphi (ok around $1k by the time you get it in there).
