Re: Which mechanical fuel pump for running tunnel ram?
[Re: 440charger500]
#1246960
06/07/12 05:03 PM
06/07/12 05:03 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
a belt driven one. doubt if a standard design can job
home of the Sox and Martin Hemi Duster
[Re: jamesc]
#1246962
06/07/12 09:16 PM
06/07/12 09:16 PM
Posts: 20,702 in a cattle trailer down by th...
Guitar Jones
most people don't seem to grasp the fact that's it's easier to feed two carburetors being you have twice the needle/seat area. there are plenty of electric pumps on the market that will do the job unless you're insisting on a mechanical pump for some reason.
Yep, I read an article in ND many years ago where WJ stated that very same concept and in fact said he used two Holley standard non return regulators because they fit his requirements at the time.
[Re: 440charger500]
#1246964
06/08/12 03:28 PM
06/08/12 03:28 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I think what they are saying is a mechanical pump that bolts to the block isnt going to supply enough fuel for 2 carbs.
67' charger 499 RB
10.57 at 127
[Re: 440charger500]
#1246965
06/08/12 03:33 PM
06/08/12 03:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Not looking to go with an electric pump, just a good mechanical that bolts in the stock location on a 440. I saw the clay smith pumps just haven't heard much about them.
I heard pretty good stuff about that pump ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 440charger500]
#1246967
06/08/12 03:46 PM
06/08/12 03:46 PM
Guitar Jones
Can you put one on the other side too? ![](/ubbthreads/images/graemlins/laugh2.gif)
I honestly don't know but I think you are asking a lot of a single feed single outlet mechanical pump.
[Re: Darryls-Demon]
#1246971
06/10/12 02:35 PM
06/10/12 02:35 PM
MR_P_BODY
I have a NEW clay smith pump I will sell cheap if you are intrested.
I assume your not happy with it.. what was the problem ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1246972
06/10/12 02:46 PM
06/10/12 02:46 PM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
After I bought the pump I found out the solid street roller cam I orderd did not have an eccentric ground into it.
[Re: astjp2]
#1246975
06/11/12 12:05 AM
06/11/12 12:05 AM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
A racepumps piston pump is good to 2000 horsepower, do you think you are going to make more than that? Tim
So they say. That said I have one and it seems to work well. They do not seem to like sucking fuel from a stock pickup (from my internet research). They work great with a sumped tank/fuel cell though. One major drawback is that they are expensive!
[Re: Jeremiah]
#1246976
06/11/12 01:32 AM
06/11/12 01:32 AM
What is expensive?
[Re: ]
#1246977
06/11/12 02:05 AM
06/11/12 02:05 AM
Jeremiah
Rogue River, OR
What is expensive?
http://www.racepumps.com/FuelPumps-DragRacing.html
