Close call, almost lost my trailer and Cuda on the way
#1246269
06/06/12 03:42 PM
06/06/12 03:42 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
to Monster Mopar this weekend: Last night I was getting ready to hook up to my enclosed trailer/car hauler for a 600+ mile trip to St Loius tomorrow. Trailer probably weighs 10,000 lbs and I'm using a weight distribution hitch and a sway bar. Every now an then when coming to a stop or cresting a hill I have heard and felt a pop from stinger moving/shifting as there is some play in the size of the receiver and the stinger which is normal so I've typically just ignored it as I've checked it in the past and everything was fine. About 2 years after I bought my 2004 Dodge 2500 4x4 Cummins I did notice that the bolts that secure the hitch to the frame cross bar were loose so I tightened them and put some lock nuts and double nutted some so they wouldn't come loosen again. So last night I wiggled the stinger just to check it and it was loose so I figured the bolts had come loose again so i proceeded to tighten them and just about the time I thought I was done I noticed that it still seemed loose and looked under the hitch and saw that the mounting tabs had broken!!!! So I was about 10 miles from loosing the trailer!!! My neighbor is going to weld and brace it back up and it will be stronger than it was but now im thinking I need to replace the whole receiver system with one that is one solid piece, frame to frame and the receiver. Here is a picture of where it broke. Has anyone else experience this? I do a lot of towing with mine, pretty much ever time it comes out of the garage it has a 10,000 lb trailer behind it but this was a very close call. ![](http://Metzinger.oxentenko.com/Hitch2.jpg)
Re: Close call, almost lost my trailer and Cuda on the way
[Re: WadeMetzinger]
#1246270
06/06/12 03:48 PM
06/06/12 03:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
To be honest... I dont think thats a 10,000 pound hitch.. normally it goes out to the frame rails... but lucky you check it all the time ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 70HemiGTX]
#1246275
06/06/12 03:58 PM
06/06/12 03:58 PM
WadeMetzinger
Tulsa, Ok
Wouldn't catch me using that to tow 10K!!!
Are you towing with a 2003 - 2008 Dodge 3/4 ton, take a look, I bet it's what your towing with.
But I agree, I would rather it be a 1 piece hitch.
I've been using this to two 10,000lb trailer since 2004, many many miles.
[Re: Red440]
#1246278
06/06/12 04:38 PM
06/06/12 04:38 PM
Posts: 20,680 in a cattle trailer down by th...
Guitar Jones
Class 5 all the way and a solid stinger, not the open square tube. I wouldn't consider anything less with that much trailer weight.
[Re: Guitar Jones]
#1246279
06/06/12 06:05 PM
06/06/12 06:05 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I am towing with a 04 3500 and the hitch looks nothing like that. To be honest I dont think I have ever seen one like that.
67' charger 499 RB
10.57 at 127
[Re: WadeMetzinger]
#1246280
06/06/12 06:06 PM
06/06/12 06:06 PM
Posts: 1,506 TN
SCATPACK 1
TN
I had that and I replaced it with a class 5 hitch, the type that goes to both side frames and bolts on in 3 different places per side. They are not that expensive and Your Insurance may not cover your trailer and car if that heavy trailer breaks loose on that light weight hitch. Wade we want you to be able to get there in one piece.
Old Geezer Racing
[Re: cudaboy]
#1246284
06/06/12 07:03 PM
06/06/12 07:03 PM
Posts: 2,527 PA
moparacer
PA
Wow, I have an 03 2500....
Going to check that out right now.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Chris'sBarracuda]
#1246286
06/06/12 08:45 PM
06/06/12 08:45 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
Nope no way I have had a 2004 Ram 2500,a 2005 Ram 3500 and a 2006 Ram 3500 and none of them had that little thing. They all had factory tow package and all had a real hitch that went from frame to frame. You have been real LUCKY
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1246287
06/06/12 09:03 PM
06/06/12 09:03 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Mine looks nothing like that,,mine is frame to frame,,and sturdy,,,,2007 ram 2500 w/ tow package,,,, Glad your ok,,,,, I would upgrade for sure,,,,I would be nervous towing with that,,,, See ya at st Louis ![](/ubbthreads/images/graemlins/beer.gif)
[Re: dusturbd340W5]
#1246288
06/06/12 09:04 PM
06/06/12 09:04 PM
Guitar Jones
I couldn't see your pic at work but now that I'm home that little dinky thing you have there looks like the hitches we added on to trucks that didn't have a tow pkg from the factory and they only went on 1/2 tons. I wouldn't pull more than 2500 pounds with that thing.
