Re: Exhaust Drone
[Re: 74RALLYE]
#1245359
08/12/12 01:55 PM
08/12/12 01:55 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
Cured my Dynomax UltraFlo drone with a pair of Magnaflow bullets on the tailpipes...Hemi style
1MYTGTX
Re: Exhaust Drone
[Re: 1MYTGTX]
#1245360
08/12/12 03:23 PM
08/12/12 03:23 PM
Posts: 141 MN
mnguy55
MN
I'm interested in trying this. Can you tell me what magnaflow muffler you used? Did you weld the tip directly to the muffler or is there a short section of pipe connecting the two?
Re: Exhaust Drone
[Re: mnguy55]
#1245361
08/12/12 04:29 PM
08/12/12 04:29 PM
Posts: 965 S.W. Pennsylvania
markrr
S.W. Pennsylvania
Please let us know. I'm interested also.
Re: Exhaust Drone
[Re: 1MYTGTX]
#1245363
08/12/12 11:24 PM
08/12/12 11:24 PM
Posts: 141 MN
mnguy55
MN
Thanks! Full write up here....
Magnaflow resonators
Thanks for the link. One more question. What tailpipes are you using? (Accurate, TTI, etc) I'm trying to figure out the longest resonator I can fit.
Re: Exhaust Drone
[Re: 63stabamatic]
#1245366
08/13/12 10:49 AM
08/13/12 10:49 AM
markrr
S.W. Pennsylvania
Thanks everyone. I've had the drone with my 2 1/2 inch TTI with H pipe and Dynomax on my 69GTX for years. After reading the posts I ordered a couple Jones 2 1/2 inch, 12" X 4" mufflers, Summit JEX-A4512B, to use as resonators. They're aluminized and a little smaller, just what I wanted. Will report back how they work. Jim
Thanks. My car is a '69 roadrunner with the same set up as yours, and it drones. I never knew what to call the the sound until this thread.
Re: Exhaust Drone
[Re: JohnH]
#1245367
08/13/12 10:53 AM
08/13/12 10:53 AM
markrr
S.W. Pennsylvania
What is the noise you all are calling drone? Ready to fire up my 440 with TTI's with mild muffles,, need to know what I might expect.... Thanks
In my case it's sort of a vibrating echo inside the car that pulses or resonates inside at around 2500 or so RPMs. If I speed up, slow down, shift, or do anything to change the RPMs the sound goes away.
Re: Exhaust Drone
[Re: JohnH]
#1245369
08/14/12 08:32 AM
08/14/12 08:32 AM
Posts: 277 Palmyra, NY
63stabamatic
Palmyra, NY
John, the "drone" is a small point in the RPM range, (2200 or 45MPH on my GTX with 3.23 gears) where the exhaust note gets so loud it's almost painful. I've been avoiding that speed quickly which is possible but I see some of the guys fixed it by putting resontors at the end of the tailpipes like the Hemi cars. I will try this soon.
Re: Exhaust Drone
[Re: 63stabamatic]
#1245370
08/14/12 09:36 AM
08/14/12 09:36 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
yea, drone...hm....how do you describe it... how about, you'll know it when you hear it! it's a hollow echo/ringing type sound that can be deafening.
I cured mine with the 12" summit glasspack as well. I don't see how the resonator/glasspack is going to hurt performance. it's a straight through flow path with louvers cut into the inside flow tube. Plus, it's all the way at the end of the exhaust where the gasses have cooled down some anyway.
**Photobucket sucks**
Re: Exhaust Drone
[Re: 63stabamatic]
#1245374
08/22/12 04:18 PM
08/22/12 04:18 PM
63stabamatic
Palmyra, NY
I did exactly as described above and it works great! Drone is gone but still a healthy rumble at idle, much more enjoyable on the highway now. You can put the Jones mufflers in two ways, I put them in the maximum through exhaust mode, still plenty quiet. Jim
