Page 2 of 3 1 2 3
Re: Exhaust Drone [Re: AnRT4Me] #1245358
08/12/12 11:12 AM
08/12/12 11:12 AM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
I have the same exhaust system on my 74 Charger with a mild 440. I started with Spin Tech mufflers and the drone was a PIA. I made some inserts for the tail pipe that made it better, but was not the cure. I switched to Dyno Max and the drone was reduced.
2 most common causes for the dreaded drone:
1- The muffler resonates due to a free flowing design and the muffler casing vibrates like a speaker.
2- Tail pipe diameter is the same diameter as the pipes in front of the muffler. The exhaust cools somewhat and the tail pipes can become something like a megaphone. If the tail pipes are 1/4" smaller, drone decreases.
Re: Exhaust Drone [Re: 74RALLYE] #1245359
08/12/12 01:55 PM
08/12/12 01:55 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Cured my Dynomax UltraFlo drone with a pair of Magnaflow bullets on the tailpipes...Hemi style
1MYTGTX
Re: Exhaust Drone [Re: 1MYTGTX] #1245360
08/12/12 03:23 PM
08/12/12 03:23 PM
MN
mnguy55 Offline
mnguy55  Offline
MN
I'm interested in trying this. Can you tell me what magnaflow muffler you used? Did you weld the tip directly to the muffler or is there a short section of pipe connecting the two?
Re: Exhaust Drone [Re: mnguy55] #1245361
08/12/12 04:29 PM
08/12/12 04:29 PM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
Please let us know. I'm interested also.
Re: Exhaust Drone [Re: markrr] #1245362
08/12/12 08:33 PM
08/12/12 08:33 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Thanks! Full write up here....
Magnaflow resonators
1MYTGTX
Re: Exhaust Drone [Re: 1MYTGTX] #1245363
08/12/12 11:24 PM
08/12/12 11:24 PM
MN
mnguy55 Offline
mnguy55  Offline
MN
Thanks for the link. One more question. What tailpipes are you using? (Accurate, TTI, etc) I'm trying to figure out the longest resonator I can fit.
Re: Exhaust Drone [Re: mnguy55] #1245364
08/13/12 09:07 AM
08/13/12 09:07 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
Thanks everyone. I've had the drone with my 2 1/2 inch TTI with H pipe and Dynomax on my 69GTX for years. After reading the posts I ordered a couple Jones 2 1/2 inch, 12" X 4" mufflers, Summit JEX-A4512B, to use as resonators. They're aluminized and a little smaller, just what I wanted. Will report back how they work.
Re: Exhaust Drone [Re: 63stabamatic] #1245365
08/13/12 10:32 AM
08/13/12 10:32 AM
WV
JohnH Offline
JohnH  Offline
WV
What is the noise you all are calling drone? Ready to fire up my 440 with TTI's with mild muffles,, need to know what I might expect.... Thanks
Re: Exhaust Drone [Re: 63stabamatic] #1245366
08/13/12 10:49 AM
08/13/12 10:49 AM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
Thanks everyone. I've had the drone with my 2 1/2 inch TTI with H pipe and Dynomax on my 69GTX for years. After reading the posts I ordered a couple Jones 2 1/2 inch, 12" X 4" mufflers, Summit JEX-A4512B, to use as resonators. They're aluminized and a little smaller, just what I wanted. Will report back how they work. Jim
Thanks.
My car is a '69 roadrunner with the same set up as yours, and it drones. I never knew what to call the the sound until this thread.
Re: Exhaust Drone [Re: JohnH] #1245367
08/13/12 10:53 AM
08/13/12 10:53 AM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
In my case it's sort of a vibrating echo inside the car that pulses or resonates inside at around 2500 or so RPMs. If I speed up, slow down, shift, or do anything to change the RPMs the sound goes away.
Re: Exhaust Drone [Re: JohnH] #1245368
08/13/12 11:03 AM
08/13/12 11:03 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
DRONE is the noise you hear when your pipes aint loud enough.
Re: Exhaust Drone [Re: JohnH] #1245369
08/14/12 08:32 AM
08/14/12 08:32 AM
Palmyra, NY
Palmyra, NY
John, the "drone" is a small point in the RPM range, (2200 or 45MPH on my GTX with 3.23 gears) where the exhaust note gets so loud it's almost painful. I've been avoiding that speed quickly which is possible but I see some of the guys fixed it by putting resontors at the end of the tailpipes like the Hemi cars. I will try this soon.
Re: Exhaust Drone [Re: 63stabamatic] #1245370
08/14/12 09:36 AM
08/14/12 09:36 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
yea, drone...hm....how do you describe it... how about, you'll know it when you hear it! it's a hollow echo/ringing type sound that can be deafening.
I cured mine with the 12" summit glasspack as well. I don't see how the resonator/glasspack is going to hurt performance. it's a straight through flow path with louvers cut into the inside flow tube. Plus, it's all the way at the end of the exhaust where the gasses have cooled down some anyway.
**Photobucket sucks**
Re: Exhaust Drone [Re: 70Cuda383] #1245371
08/14/12 10:24 AM
08/14/12 10:24 AM
WV
JohnH Offline
JohnH  Offline
WV
Thanks for the info,, I retired out of the Air Force and thought you were talking about a spy plane ... I hope I don't have that noise when I get this car on the road..
Re: Exhaust Drone [Re: mnguy55] #1245372
08/14/12 10:29 AM
08/14/12 10:29 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Thanks for all of the replies so far, as I will be trying some of these suggestions to get my exhaust OUT OF THE DRONE ZONE!!!!!
I wish I had seen this post before I bought my TTI system. I have a 70 Charger R/T. I just put on the same system you have and it's exactly the same, terrible drone at about 40 MPH. I called TTI and they said they had never heard of a issue with drone with this system. Apparently I'm not the only one.
Have you tried anything yet? I replaced the Dynomax Super Turbos with Thrush Turbos. Same size but different internals. It helped a little but not enough.
try some dynomax VT's if you don't want to put a glasspack as a resonator in the tailpipe
2017 Grand Cherokee Overland
Re: Exhaust Drone [Re: patrick] #1245373
08/14/12 01:10 PM
08/14/12 01:10 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
My 2 1/2 X 12 glass packs slowed my car 1.5 mph. Ive been told since then that glasspacks are the biggest HP robbers of any straight through muffler
Re: Exhaust Drone [Re: 63stabamatic] #1245374
08/22/12 04:18 PM
08/22/12 04:18 PM
Palmyra, NY
Palmyra, NY
I did exactly as described above and it works great! Drone is gone but still a healthy rumble at idle, much more enjoyable on the highway now. You can put the Jones mufflers in two ways, I put them in the maximum through exhaust mode, still plenty quiet.
Re: Exhaust Drone [Re: 63stabamatic] #1245375
08/22/12 10:15 PM
08/22/12 10:15 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Re: Exhaust Drone [Re: 63stabamatic] #1245376
08/25/12 01:20 AM
08/25/12 01:20 AM
MN
mnguy55 Offline
mnguy55  Offline
MN
I just added magnaflow 4" mufflers as resonators on my 70 Charger. I just got back from the test drive and it's a sucess. No more drone at 40 & 60 MPH. It still has a very deep sounding idle, a little deeper than I'd like but not bad. Driving is great. Sounds nice but you can listen to the radio with the windows up at 60 MPH. The only bad thing is I now hear a lot more noises that were covered up by the exhaust.
Re: Exhaust Drone [Re: AnRT4Me] #1245377
08/25/12 02:07 AM
08/25/12 02:07 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Some more info and performance results at the end of the thread...........
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Page 2 of 3 1 2 3
