Carter, Edelbrock, or Holley? #1244625
06/03/12 03:07 AM
06/03/12 03:07 AM
Spokane Valley, Washington
stryker63 Offline OP
Greetings,
I am finally returning to my project after an extended period of unemployment. It is a ’73 Plymouth Gold Duster resto-mod. Power plant is a warmed over ’99 5.2L Magnum. Block is bored over 0.03” with a higher duration cam (duration @ 0.05 216 intake/224 exhaust), hypereutectic pistons, heavier (LS1) valve springs, and double timing chain, but otherwise stock. Goal is right around 290-300hp.
Intake is an Edelbrock RPM Air-Gap (7577) manifold. I would like to run a Thermoquad but have heard they are not compatible with this intake. The Edelbrock guys suggest a 1407 (manual choke) or 1411 (electric choke) 750 cfm carb. I have also looked into the base 600 cfm Summit Racing carb or a smaller Holley (4160 or similar).
My question is this: What carb would best complement this intake? I have been advised to try and stay within a range of 600-700 cfm. This is a low budget build so high-end or exotic carbs are not doable.
Thanks for any and all opinions.
Re: Carter, Edelbrock, or Holley? [Re: stryker63] #1244626
06/03/12 03:40 AM
06/03/12 03:40 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
First & formost: STAY AWAY from the 1407 / 1411 Edelbrock carbs. Garbage!
I'd suggest a Holley 650 Street Avenger series for your combo.
Re: Carter, Edelbrock, or Holley? [Re: stryker63] #1244627
06/03/12 03:41 AM
06/03/12 03:41 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Holley or a Thermobog
Re: Carter, Edelbrock, or Holley? [Re: DAYCLONA] #1244628
06/03/12 03:53 AM
06/03/12 03:53 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Hollet 3310 750 vac secondarys
I am truckless..
Re: Carter, Edelbrock, or Holley? [Re: stryker63] #1244629
06/03/12 09:44 AM
06/03/12 09:44 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
With 216/224 duration at .050...........
Why would you want more cfm that you need and less throttle response off idle????? Poorer gas mileage too.
Do the 600-650 carb. 600 Holleys are inexpensive at swapmeets and on this sites Classifieds Section.
Don't overcarb. That 5.2/318, now 322, will scream nicely with a 600 Holley and pull down high teens in mileage. Even better with a 625 AFB with the jets/metering rods tweaked.
Worse case, you can sell the 600-650 carb later for what you paid for it and upgrade to that 750 when you're ready to throw more gas money at it.
Re: Carter, Edelbrock, or Holley? [Re: Dean_Kuzluzski] #1244630
06/03/12 11:03 AM
06/03/12 11:03 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Go Thermoquad. Way better than a holley or afb! Better mpg, more power. Best street carb out
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Carter, Edelbrock, or Holley? [Re: stryker63] #1244631
06/03/12 11:05 AM
06/03/12 11:05 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
650 Holley. Or anything but an Edelbrock 750.
Re: Carter, Edelbrock, or Holley? [Re: stryker63] #1244632
06/03/12 11:15 AM
06/03/12 11:15 AM
Truckville, the capital of NY
85_Ram_4speed Offline
Since you said low budget, get a 600 cfm Holley and rebuild it. They are usually found cheap enough and you can rebuild them and buy the carb for around $100.
I agree the regular Edelbrocks are not the greatest, in my opinion only due to the lack of an adjustable secondary air door. The Thunder series Edelbrock on the other hand is an excellent choice. But I think they run around $350.
Both carbs will require the Chrysler throttle cable bracket too, so by that for which ever carb when you get the rebuild kit.
If this is a street car (which it sounds like), keep the CFM on the smaller side---you'll be much happier.
Outcast Dodge guy.
Re: Carter, Edelbrock, or Holley? [Re: 85_Ram_4speed] #1244633
06/03/12 11:35 AM
06/03/12 11:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Holley. 650HP would work nice, but if you want to save a few $$ you can always get an old school 750 vac carb.
Coming soon!!!!
Re: Carter, Edelbrock, or Holley? [Re: Mr.Yuck] #1244634
06/03/12 12:03 PM
06/03/12 12:03 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Rebuilt Carter AVS or a new Edelbrock AVS. Do not run an AFB, the Holley 1850 is a cheap alternative as well.
Sheldon
Re: Carter, Edelbrock, or Holley? [Re: stryker63] #1244635
06/03/12 02:17 PM
06/03/12 02:17 PM
Central NC
gch Offline
gch  Offline
Central NC
A 600 holley will be fine and dandy.If you happen to stumbel on a 650 vacuum secondary all the better.Even a 600 double pumper would work well.
You can always mill the choke horn or do a main body swap on a 600 for a little more flow.
Re: Carter, Edelbrock, or Holley? [Re: gch] #1244636
06/03/12 02:47 PM
06/03/12 02:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The Eddy 7577 looks like a square-bore, so the T-quad won't fit without an adapter or some modification. Not enough room under a Duster/Dart/Demon/Valiant hood for an adapter. You can use the regular Performer for a T-quad; look at the carb base area on the intake for a larger secondary opening. Look at the Weiand & others as well.
I really like the T-quad or AVS-style carbs for the street, and 600-650CFM is all you'll need under about 7,000 RPM for your combo. Holleys are easy to tweak, but in my experience usually get a bit less MPG. Depending on what air cleaner you plan to use, the carb throat size may pose a problem.
Re: Carter, Edelbrock, or Holley? [Re: stryker63] #1244637
06/03/12 05:47 PM
06/03/12 05:47 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
The carters. eddys and TQ's are not the best choise for a bigger cam motor. There idle circut is off vacunm and with bigger cam you have less vacunm. Also all above mentionedhave a heat soak problem and hard restart after warmed up. I'd suggest the Holley. I do prefer the Quick fuel carbs. Holley design with more features and less cost. Very nice street carb.
Re: Carter, Edelbrock, or Holley? [Re: Dougsmopars] #1244638
06/03/12 06:07 PM
06/03/12 06:07 PM
Holly/MI
Holly/MI
WOW!! Pretty wide range of responses!
Bottomline.........the 600 Holley is hard to beat when they can be had all day long at swapmeets for $40 or less.
I've run a Carter AFB for over 17 years and NEVER a heatsoak problem. ONE bad needle/seat and that's it. Very simple efficient carbs that are easy to tune & service, especially with his cam.
Still say a 750 is overkill and gas mileage will suffer.
Re: Carter, Edelbrock, or Holley? [Re: Dean_Kuzluzski] #1244639
06/03/12 06:55 PM
06/03/12 06:55 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
' Very simple efficient carbs that are easy to tune & service'
Exactly...
Have had a 'garbage' 1411 on top of a 440 for 20 years...
ZERO issues...
Compare an exploded view of a Holley, vs. a Carter...
There's your answer...
Re: Carter, Edelbrock, or Holley? [Re: Dougsmopars] #1244640
06/03/12 07:11 PM
06/03/12 07:11 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Only difference in the QF v older hollies v other carbs is that QF have circuits with adjustable bleeds. You can do the same with drill bits and wire and or drilling and tapping your own.
The adjustable circuits do you NO GOOD what-so-ever if you dont understand them or have a way to see the tuning effects caused by them.
I personally prefer TQ but opinions are like A-holes, everyone has one and they all stink.
All carburetors can be tuned the same, read ALL CARBS CAN BE TUNED THE SAME.
Have someone tear one apart in front of you and decided which one looks the easiest for you to fix, it your ride, you ll have to fix it.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Carter, Edelbrock, or Holley? [Re: RSNOMO] #1244641
06/03/12 07:20 PM
06/03/12 07:20 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
I installed a garbage 1411 on the 451...
Never had problems when you know how to tune it.
I used Holley on many engines good carb but now I prefer Edelbrock.
Re: Carter, Edelbrock, or Holley? [Re: kilroy] #1244642
06/03/12 10:09 PM
06/03/12 10:09 PM
Dougsmopars Offline
Dougsmopars  Offline
The QF carb also has adjustable vac diaphram for secondaries so no need to mess around with springs like a stock holley.
Re: Carter, Edelbrock, or Holley? [Re: Dougsmopars] #1244643
06/03/12 11:03 PM
06/03/12 11:03 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
so do TQs and Eddy AVS and Qaudjets. again THEY ALL ARE THE SAME in what they do. find one and get comfy, or try them all and have fun with everyone.
No one carb is going to demystify working on them or tuning them. They are either tuned right making them the "BEST" carb or completely out of tune and or the motor is not in time and they are the "WORST" carb.
Again, find one and get comfy; short of dropping one if you follow rebuild instruction you cant "break one".
Re: Carter, Edelbrock, or Holley? [Re: kilroy] #1244644
06/04/12 05:23 AM
06/04/12 05:23 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Relax.
The QF Slayer series of carb ($300) uses an externally adjustable vacuum secondary dash-pot. It also has idle bleeds in the main body and the secondary metering plate is drilled for jets.
That said if you don't have the tune up parts you will be spending a little more to tune the carb to perfection.
Re: Carter, Edelbrock, or Holley? [Re: Jeremiah] #1244645
06/04/12 08:31 AM
06/04/12 08:31 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Relax.
I must be missing something. Cheers mates. Out.
Re: Carter, Edelbrock, or Holley? [Re: Jeremiah] #1244646
06/04/12 01:35 PM
06/04/12 01:35 PM
dogdays Offline
dogdays  Offline
My experience with a Holley 570 Street Avenger on my 318 is that it's WORLDS ahead of the 1850. I thought I'd jetted the 1850 down enough for the altitude (going from 66 to 59), but swapping on the 570 gave me an immediate 2 mpg and a much sharper-running engine.
I don't understand why, but there must have been SOME improvements in fuel metering in the last 30 years!
You can usually buy used 570s on the 'bay for around $100.
R.
Re: Carter, Edelbrock, or Holley? [Re: dogdays] #1244647
06/04/12 02:19 PM
06/04/12 02:19 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I too have an Avenger series carb (670 CFM) on the 318 in our W100 and it have been a great carburetor. They have come down a little in price too.
