Re: Big bolt pattern Drums for a A Body with stock brakes
[Re: Mpetros]
#1241954
05/29/12 11:43 PM
05/29/12 11:43 PM
Posts: 20,230 Park Forest, IL
slantzilla
Park Forest, IL
Moser used to drill axles and drums for about $100.
[Re: Mpetros]
#1241956
05/30/12 06:26 AM
05/30/12 06:26 AM
Posts: 75,134 A Banana Republic near you.
JohnRR
Someone told Me that a 65 or 66 B Body with a 6 Cyl and a 7 1/4 Rear has the big bolt pattern and the 1 3/4 wide brakes looking it up they show 1 3/4 wide brake shoes but no drum pt#
Yes that is the application for the drum ... up to 70 ... good luck finding it. The last time I saw them the seller wanted $300 EACH. If you try to put these on redrilled stock axles you will have to make a spacer ring for the center hub.
I'd like to have a pair of them myself .
[Re: JohnRR]
#1241957
05/30/12 08:30 AM
05/30/12 08:30 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Why dont you want BBP discs ?
I am truckless..
[Re: Rhinodart]
#1241961
05/30/12 12:11 PM
05/30/12 12:11 PM
JohnRR
I had heard of the B-Body drums, but in 34 years of working on Darts I too have never seen a set and I have converted dozens of rear brakes.
I actually owned a car that would have had them ... 68 coronet 4 door with a /6, pretty sure it had a 7.25 rear in it, parted it almost 20 years ago ....
I'm going to make a call, I may be able to get my hands on one.
[Re: JohnRR]
#1241964
05/30/12 02:30 PM
05/30/12 02:30 PM
moparpollack
Lil Herman
Lil Herman
85086
So the drums on these cars are worth some coin. Next time I'll keep this in mind before I sell them for a penny a pound. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Mpetros]
#1241965
05/30/12 03:30 PM
05/30/12 03:30 PM
Posts: 1,357 central Florida
VL21
central Florida
No one has asked, so I will. Are the axles the stock a body ones that have been re-drilled to the big pattern? Or are they cut down big car ones, or aftermarket? ![](/ubbthreads/images/graemlins/whistling.gif)
It takes gasoline to interest me.
[Re: moparpollack]
#1241966
05/30/12 03:38 PM
05/30/12 03:38 PM
JohnRR
Pretty much, I didn't even know this drum existed till this question came up within the last year and I looked in my factory parts manual.
I'm either reading into the OPs question too much or some are missing the point.
Here is how I see the question being asked ....
I am buying larger bolt patten AFTERMARKET axles to REPLACE the stock small bolt pattern axles . I have to keep the original factory track width because my tires are too close to my quarter panels using stock factory steel wheels ... which I have to run for the class I race in ... this means I must keep my stock axle offset and 1.75 wide brake shoes because I am using HUBCENTRIC rims.
If I drill out my stock axles and brake drums then I need to make a spacer to run hubcentric wheels, but I'm going to be running a spool and I have to use green bearings I have to switch to an aftermarket axle to be SAFE on the track.
Is there a drum that will fit the factory A body axle hub offset and works wit hthe stock A body brakes ?
The answer is YES ...
[Re: VL21]
#1241967
05/30/12 03:39 PM
05/30/12 03:39 PM
JohnRR
Valid question that we all seem to be ASSuMEing the answer in order to TELL the OP what to do .
[Re: VL21]
#1241968
05/30/12 10:19 PM
05/30/12 10:19 PM
Posts: 295 Greensburg, Pa
Mpetros
Greensburg, Pa
The Axles are Moser, Ok heres the Story, A local Guy walks in My Shop with a pair of A body small bolt Stock axles. He wanted to buy big bolt pattern Axles. I then asked what brakes are you going to use your stock or B Body. He replied I like to use My stock brakes, so I ordered from Moser A body length axles with big bolt pattern. So He called me the other day and said he cant find a drum to fit, so I then said I can redrill your stock drums to 5 on 4 1/2. He said he didnt want to do that because it would weaken it.I explained that the rim is clamping the drum to the Axle, even with 5 extra holes it would still be safe. I then said Ive sold Hundreds of Axles with Dual patterns for racing and on the street. Still I could not convince him to redrill his drums.. So I told him I would look into finding something that might work. any help would be appreciated ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Mpetros]
#1241969
05/30/12 11:24 PM
05/30/12 11:24 PM
JohnRR
Do the axles have the big bolt pattern center register or the small bolt pattern center register ? Do the axles with the B/E offset or the A offset ?
