Re: is 650cfm enough? [Re: Jerry] #1241618
05/30/12 09:19 PM
05/30/12 09:19 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I bet it will run better with the 650 than it will with the 750. Stock convertor, stock cam.
Sheldon
Re: is 650cfm enough? [Re: RUNCHARGER] #1241619
05/30/12 11:29 PM
05/30/12 11:29 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you didn't mention your manifold but either way a 650 on a 383 auto car is pretty sweet.
Re: is 650cfm enough? [Re: mikemee1331] #1241620
05/31/12 12:14 AM
05/31/12 12:14 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
You guys are nuts!!! Drop a 1050 Dom & don't look back...............
JK, the 650dp will be fine.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: is 650cfm enough? [Re: joedust451] #1241621
05/31/12 01:07 AM
05/31/12 01:07 AM
Warren, MI
Jerry Offline OP
Jerry  Offline OP
Warren, MI
right now the engine is all stock including the cast iron 4bbl intake. i would love to build this up as a "FAST" style engine build but i don't know if its in the budget. so most likely its going to get a mopar 528 mechanical cam and true flat top pistons and have the heads ported, but keep the stock sized valves. again i'm not looking for all out race performance just a good driver thats got some power under the hood. i think about 450 hp will be plenty. i don't see this engine revving past 5500 any time soon either.
and yes its an auto with a stock converter but i will change out the coverter once i get the engine rebuilt. and the trans will get a shift kit just firm up the shifts some.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: is 650cfm enough? [Re: Jerry] #1241622
05/31/12 02:06 AM
05/31/12 02:06 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
My friends 440 made quite a bit more power than it oughta... had pretty good top end too... that was a Holley 670 Street Avenger that i tuned for him. My 440 was the same way... junk that ran like a built engine... that was only a 750. That 650 with a solid tune should be fine, especially for what you're after and with what you have. When the time comes and you need more, if you're a tuner, you can get quite a bit more airflow out ov that 650 even. There are quite a few lil tricks that will net you more CFM and you can get into the 700's without buying a new body or carb... yet, you'll still have the small-carb driveability. My friend's 440 always did daily-drive a bit better than mine did.
I've always been a fan ov doing the most you can with the least. Anyone can dump on an 850DP and run, but the car will like the smaller carb almost every time, and in many cases run quicker anyways.
All that said, if you happen across a nice 750 i'd pick it up... but theres no rush to do so.
Re: is 650cfm enough? [Re: Pale_Roader] #1241623
06/01/12 10:53 AM
06/01/12 10:53 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Had a Holley 670 Street Avenger on my '68 road runner with an old Edelbrock DB4 intake and a Comp Cam and stock exhaust manifold and Ultra Flo's.....BEST combo I ever had...changed the PV's up one size and drove it and drove it and just a no hassle turn key set-up. Liked the Holley 670 so much on the 383, when I got the '69 GTX 440 I put a Holley 770 SA on it right away...same result "plug and play"
Re: is 650cfm enough? [Re: A12] #1241624
06/01/12 10:57 AM
06/01/12 10:57 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Go to Advance Auto and order the Holley online and you save on shipping and usually there's discounts on over a certain amount purchase or most of the Adv Autos will price match even places like Summit's price and as I said no shipping charges. There's also links to Advance Auto discount codes/coupons.
Re: is 650cfm enough? [Re: Jerry] #1241625
06/01/12 11:02 AM
06/01/12 11:02 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I just bought a proform 750..dual feed/double pump/electric choke/bowl sight glasses,easy air bleed change for 439 delivered. 750 will run well on your 383 and even better with the future mods mentioned
