Reaction times. The smaller the front tire the quicker your reaction times will be. If you are racing on a .400 Pro Tree you generally need all you can get.
FWIW my big tire car has a 33" rear tire and I run a 26" tire on a pro tree. But it is a tube chassis car, which is a different animal than what you are building.
