Re: super stealth - opened to maxwedge size?
[Re: LaRoy Engines]
#1240889
05/28/12 04:25 PM
05/28/12 04:25 PM
Posts: 33 germany
smoke
germany
@heyoldguy ok, i'm fairly new to mopar and in germany it's an even more uncommon hobby. My knowledge is still on noob-status (but the library is growing!) Right now i have in the car a 440 with 906's, rpm-intake and a 770cfm carb.... I have no further info on the internals (only the number on the pistons told me that they are stock). So my guess is this combo is around 300HP. Since i want some more bang ![](/ubbthreads/images/graemlins/Dino2.gif) i bought an unused 0.30over 76 block. With the block came a 4.150 stroker-crank (+ pistons + rods) and so i'll go for 493cubes. Compression 11:1 would be fine on pump-gas. The goal is 750HP (means around 600HP on rear-axle). I red threads where you also posted, that for reaching 750 maxwedge is not really needed. I assume that everything has to be built properly from the right pro without any mistakes to reach the 750HP. To be more on the secure side (some imperfections might happen in the engine-building-process or the builder is not 100% perfectly doing his job) i had the idea to go with mw-heads and a double plane indy 440-1 intake. Ok, still would need someone to pick the right cam for me.. ;-) ANY ADVICE what combo would also bring me to the 750HP-region ( no problem if it's "only" 725... ![](/ubbthreads/images/graemlins/grin.gif) ) is welcome. The only things i have right now are: Eagle 4150 crank Eagle 6760 rods Speed Pro forged pistons L2266F Clevite M bearings (think "M" is for racing and i should go for "H") ARP bolts 440 block bored 0.030 over thanks + regards,smoke
[Re: smoke]
#1240890
05/28/12 07:55 PM
05/28/12 07:55 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
well what i found on L2266F is with a 4.15 stroke and 6.678 rod they will stick over .100 out of the block?? Other than that I would go with Indy 440-1 kit right from the get go and have CNC ported before it is shipped to you comes with everything you need then you just need a cam. what you need for where you want to go!! comes with intake and all. and maybe upgrades in valve springs for roller cam and upgrade rockers to harland sharp or T&D and so on. Guys can give you the names of some guys on hear to buy from or wes at mancini racing. http://www.manciniracing.com/440-1 head kit! they will get them CNC at modern or by Indy and upgrades you need http://chucker54.stores.yahoo.net/in44hepr850h.htmlmaybe get the open access valley plate too well for sure!
[Re: Dodgem]
#1240891
05/28/12 08:08 PM
05/28/12 08:08 PM
Dodgem
Ontario, Canada
You may want to slide over to "Unlawful racing and engine tech" section and title along the lines of "help me build a 750 hp pump gas motor" Lay out exactly what you have and goals EZ heads are only needed where clearance is an issue like an A body. on a B body just get the TTI indy headers 2 to 2 1/8 step headers for 440-1 and SR heads can be boght through Mancini's ask for you moparts discount! :-) http://www.ttiexhaust.com/Header-TTI440-218/HeaderDetails.htm
[Re: 383man]
#1240894
05/28/12 11:04 PM
05/28/12 11:04 PM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
No, its the SR heads that are needed for A-body clearance issues. The EZ heads have a standard height exhaust port, SR's have a raised port.
[Re: Stanton]
#1240895
05/29/12 11:28 AM
05/29/12 11:28 AM
Dodgem
Ontario, Canada
Sr's are raised and extened very tight in an A body The EZ's with stock location give more room!
[Re: Dodgem]
#1240897
05/30/12 06:46 AM
05/30/12 06:46 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
X3 , the EZ's are best used in A bodies.
[Re: JohnRR]
#1240898
05/30/12 09:30 AM
05/30/12 09:30 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I believe Indy actually made the EZ heads for the A-body since it is a tighter fit then the B-body. The other Indy heads with the raised exh port had problems in the A-bodies with fitting right and not hitting things. So this Indy head (the EZ) was done by Indy as one of their good heads but with the exh ports in standard location so headers made for A-bodies made for standard exh port location will fit good in the A-body. Indy raised its exh port to get better flow on their heads. But after seeing the problem with fitment on A-bodies they came out with the EZ heads and standard exh port location. Of course you can use them on any car but they do fit better on the A-bodies then other Indy heads. Also the EZ heads use stock rocker gear and not offset rockers. I myself use the EZ heads on my 63 as I wanted the standard exh port location and standard rocker arms. Its less hassle and cost then if I used any other Indy head. I could probably make more power with a different Indy heads but the EZ's make pretty good power for having the standard exh port location. Ron
[Re: 383man]
#1240899
05/30/12 10:19 AM
05/30/12 10:19 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
![](/ubbthreads/images/graemlins/iagree.gif) The SRs require the expensive TTI headers or a custom set, but they probably have more potential than the EZs due to the raised ports. The EZs, though designed for A-bodies, will work in B and E-bodies as well and don't require the special headers. The EZs might be able to make 750 HP, but you'd have to ask around. The SRs can make 750 HP more easily, in my opinion. Both the SRs and EZs use standard rockers, but the 440-1 heads (which aren't necessary if you're only trying for 750 HP) require off-set rockers. Ithink that the Super Stealths would require quite a bit of work to make 750 HP. ![](/ubbthreads/images/graemlins/Twocents.gif)
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 1968RR]
#1240900
05/30/12 04:18 PM
05/30/12 04:18 PM
Posts: 33 germany
smoke
germany
guys, thanks for all of your valueable input. The picture gets more clear... from post to post... I will have a very close look for ported and matched EZ (opened to mw) + indys 440-2d intake. Since i want to go with stock hood i have only few options regarding the intake in mw-size. If there is another solution (maybe opened but not fully to mw-size and taking a better flowing intake) that will have nearly the flow of the components above... let me know. For now i'll have a ![](/ubbthreads/images/graemlins/drinking.gif) on you.
[Re: smoke]
#1240904
05/31/12 10:34 AM
05/31/12 10:34 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
750 hp in USA $$$ I would bet you start at $10,000 and just go up from there.
ABSOLUTELY !!!
I am putting the finishing touches on a 526" stroker and am well over $10,000 after having found some VERY good deals
Worth noting here is that according to Desktop Dyno this combo will only make 515 HP at 5000 RPM. However it will make 568 ft/lb of torque at 2000 and peak torque of 604 at 4000. This is a conservative estimate as apparently DD loses some accuracy when the cubic inches start to climb. This is with a .600 roller cam and 1.5 rockers. So this should give you some idea of what you need to do and invest to hit your HP goal. Also note that after buying the head "kit" from Indy, almost everything was changed - this why you buy Indy heads from someone else!
Block $150.00 Hot tank $50.00 Sonic test $212.00 Line hone block $175.00 Deck block $175.00 Bore and hone block $175.00 Inst cam brgs $50.00 fit rings $60.00 clean & assemble shortblock $250.00 cam brgs $45.00 Cam (roller) $320.00 Oil pump drive gear - bronze $110.00 Valve springs $130.00 Valve retainers $53.00 Valve locks $23.00 Valve spring shims $7.00 Valve seals (teflon) Spring cups $65.00 Inst. spring cups $100.00 Head Gaskets $150.00 Ign. Syst. (Firecore) $360.00 Headers (Doug's #D452) $639.94 Rocker assys. - Harland Sharp $350.00 Rocker shafts $159.00 Rocker shaft holddowns $45.00 ARP Rocker stud set $59.00 Roller lifters $650.00 Pushrods $185.00 Aluminum Distributor Hold down Clamp $18.95 Timing cover - cast aluminum $100.00 Billet aluminum timing pointer $39.95 ARP Main Stud Kit - 12pt $59.95 Rear Main Seal Cap - Billet $36.95 Rear Seal Cap Bolts - Set of 2 $9.95 Viton Rear Seal $24.95 Viton Rear Seal End Strips Kit $7.95 Intermediate Shaft Bushing $7.95 stroker kit with rod and bolt upgrade $1,967.00 Block pkg. Indy ez1 head kit $2,300.00 Indy dual plane intake $469.00 Throttle bracket $55.00 Return spring bracket $25.00 Indy plain valve covers $160.00 Timing set $100.00 Water pump housing $75.00 Water pump Billet water neck $35.00 Motor mounts $150.00 440source fluid damper $134.95 Starter $40.00 Lightweight Alternator Retrofit Kit $159.95 Billet Aluminum Single Belt Serpentine Pulley Set $129.95 Serpentine belt $19.95 Milodon dual line oil syst. & pan $1200.00 Total ... $12,075. and I haven't put a carb on it yet !!
[Re: Stanton]
#1240905
05/31/12 10:43 AM
05/31/12 10:43 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
642 HP and 642 TQ all by 5800 rpm
Are these REAL dyno numbers or from some program? Other than the cubic inches my build above is very similar ... same cam, compression, carb, etc. but the numbers differ significantly. I'm taking the Desktop Dyno numbers with a grain of salt, I know the motor will definitely put out more than DD says.
Oh, and to the OP ... Indy EZ1 heads require no external oiling and use standard offset rockers.
[Re: Stanton]
#1240906
05/31/12 11:02 AM
05/31/12 11:02 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
REAL! I will NEVER quote dyno numbers I haven't produced on a dyno. I don't even mess with desktop dyno numbers.
[Re: LaRoy Engines]
#1240907
05/31/12 11:20 AM
05/31/12 11:20 AM
dogdays
Note to OP:
Unless your octane ratings use the (RON + MON)/2 formula, your octane rating is probably the same as 93 octane would be in the States.
Back in the day the pumps here had only RON, Research Octane Number, posted. The other octane rating, MON, was usually 8 to 10 points lower. So when they are averaged the 98 becomes 93 or 94.
Now on an aluminum headed engine with decent combustion chambers and a big cam I'd agree you could probably go another point of compression, say 11.3:1.
The main point of my last post was that you seemed to be after 750hp for bragging rights. I don't think you need them. 650 hp will move your car to around 300kph. If you want those big numbers I'd suggest turbochargers. Otherwise, as others are telling you, that number might cost you close to $20K.
R.
[Re: dogdays]
#1240908
05/31/12 01:46 PM
05/31/12 01:46 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
-Solid roller 249/255 @ .050" .585"/.600" lift + roller lifters
I'd guess that's the Lunati 60333! That's the cam I have. Are you using 1.5 rockers? Which lifters?
