Re: super stealth - opened to maxwedge size?
[Re: smoke]
#1240904
05/31/12 10:34 AM
05/31/12 10:34 AM
Posts: 8,928 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
750 hp in USA $$$ I would bet you start at $10,000 and just go up from there.
ABSOLUTELY !!!
I am putting the finishing touches on a 526" stroker and am well over $10,000 after having found some VERY good deals
Worth noting here is that according to Desktop Dyno this combo will only make 515 HP at 5000 RPM. However it will make 568 ft/lb of torque at 2000 and peak torque of 604 at 4000. This is a conservative estimate as apparently DD loses some accuracy when the cubic inches start to climb. This is with a .600 roller cam and 1.5 rockers. So this should give you some idea of what you need to do and invest to hit your HP goal. Also note that after buying the head "kit" from Indy, almost everything was changed - this why you buy Indy heads from someone else!
Block $150.00 Hot tank $50.00 Sonic test $212.00 Line hone block $175.00 Deck block $175.00 Bore and hone block $175.00 Inst cam brgs $50.00 fit rings $60.00 clean & assemble shortblock $250.00 cam brgs $45.00 Cam (roller) $320.00 Oil pump drive gear - bronze $110.00 Valve springs $130.00 Valve retainers $53.00 Valve locks $23.00 Valve spring shims $7.00 Valve seals (teflon) Spring cups $65.00 Inst. spring cups $100.00 Head Gaskets $150.00 Ign. Syst. (Firecore) $360.00 Headers (Doug's #D452) $639.94 Rocker assys. - Harland Sharp $350.00 Rocker shafts $159.00 Rocker shaft holddowns $45.00 ARP Rocker stud set $59.00 Roller lifters $650.00 Pushrods $185.00 Aluminum Distributor Hold down Clamp $18.95 Timing cover - cast aluminum $100.00 Billet aluminum timing pointer $39.95 ARP Main Stud Kit - 12pt $59.95 Rear Main Seal Cap - Billet $36.95 Rear Seal Cap Bolts - Set of 2 $9.95 Viton Rear Seal $24.95 Viton Rear Seal End Strips Kit $7.95 Intermediate Shaft Bushing $7.95 stroker kit with rod and bolt upgrade $1,967.00 Block pkg. Indy ez1 head kit $2,300.00 Indy dual plane intake $469.00 Throttle bracket $55.00 Return spring bracket $25.00 Indy plain valve covers $160.00 Timing set $100.00 Water pump housing $75.00 Water pump Billet water neck $35.00 Motor mounts $150.00 440source fluid damper $134.95 Starter $40.00 Lightweight Alternator Retrofit Kit $159.95 Billet Aluminum Single Belt Serpentine Pulley Set $129.95 Serpentine belt $19.95 Milodon dual line oil syst. & pan $1200.00 Total ... $12,075. and I haven't put a carb on it yet !!
[Re: Stanton]
#1240905
05/31/12 10:43 AM
05/31/12 10:43 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
642 HP and 642 TQ all by 5800 rpm
Are these REAL dyno numbers or from some program? Other than the cubic inches my build above is very similar ... same cam, compression, carb, etc. but the numbers differ significantly. I'm taking the Desktop Dyno numbers with a grain of salt, I know the motor will definitely put out more than DD says.
Oh, and to the OP ... Indy EZ1 heads require no external oiling and use standard offset rockers.
[Re: Stanton]
#1240906
05/31/12 11:02 AM
05/31/12 11:02 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
REAL! I will NEVER quote dyno numbers I haven't produced on a dyno. I don't even mess with desktop dyno numbers.
[Re: LaRoy Engines]
#1240907
05/31/12 11:20 AM
05/31/12 11:20 AM
dogdays
Note to OP:
Unless your octane ratings use the (RON + MON)/2 formula, your octane rating is probably the same as 93 octane would be in the States.
Back in the day the pumps here had only RON, Research Octane Number, posted. The other octane rating, MON, was usually 8 to 10 points lower. So when they are averaged the 98 becomes 93 or 94.
Now on an aluminum headed engine with decent combustion chambers and a big cam I'd agree you could probably go another point of compression, say 11.3:1.
The main point of my last post was that you seemed to be after 750hp for bragging rights. I don't think you need them. 650 hp will move your car to around 300kph. If you want those big numbers I'd suggest turbochargers. Otherwise, as others are telling you, that number might cost you close to $20K.
R.
[Re: dogdays]
#1240908
05/31/12 01:46 PM
05/31/12 01:46 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
-Solid roller 249/255 @ .050" .585"/.600" lift + roller lifters
I'd guess that's the Lunati 60333! That's the cam I have. Are you using 1.5 rockers? Which lifters?
