Re: Carb backfire- with flame. [Re: Cab_Burge] #1238737
05/27/12 02:05 AM
05/27/12 02:05 AM
Tomorrow.
Damned67 Offline OP
Damned67  Offline OP
Tomorrow.
Right, dropped and emptied the fuel tank.
Also removed the carb for a refresh. During the process, I because less than confident of one of my floats. So it's all back together, but I've decided to wait until I replace the float during the week before I fire it up.
Re: Carb backfire- with flame. [Re: Damned67] #1238738
05/27/12 08:15 AM
05/27/12 08:15 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
The only times I have ever had this problem is if I pulled the distributor out and "put it back in exactly the same position as it was before". Yea right. I always had the timing retarded too far. Usually bump it up and it will be fine. Never had to drain the tank of fuel and put fresh in it. Yes it does burn differently when old, but I never had a problem with it.
