1970 B-body seat belt setup? #1238258
05/23/12 03:53 PM
05/23/12 03:53 PM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Supposedly the seat belts in 1970 are different from 68/69 for b-bodies but in what respect?
On my 70 Charger (built february 1970) there is just a single buckle on each front seat next to the transmission tunnel which is non adjustable in length. The lap belt bajonet clicks into the buckle and the should belt attaches to the bajonet of the lap belt. The buckle is not a lift-up style like the 68/69 buckles but has a button in the middle. Is this the correct 70 setup?
I've seen pictures of 70 chargers having two buckles on the transmission tunnel side...
What about the rear belts. are they the same as 68/69? how should they be stored?
any pictures of a correct 70 setup?
Re: 1970 B-body seat belt setup? [Re: DGS] #1238259
05/23/12 10:57 PM
05/23/12 10:57 PM
Washington
69440 Offline
69440  Offline
Washington
Sounds like what you have are "Deluxe" seat belts. You'ld have an option code C-15 if the was originally equipped with deluxe belts. I'll post a pic of some deluxe belts for an E-Body, and some standard belts for a B-Body.
Re: 1970 B-body seat belt setup? [Re: 69440] #1238260
05/23/12 10:59 PM
05/23/12 10:59 PM
Washington
69440 Offline
69440  Offline
Washington
B-Body belts
Re: 1970 B-body seat belt setup? [Re: 69440] #1238261
05/23/12 11:46 PM
05/23/12 11:46 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here is info on the deluxe belt option fron the dealer data book. A "fasten seat belt" light is also part of it.
Neat option to have!
Re: 1970 B-body seat belt setup? [Re: moparfan53] #1238262
05/24/12 06:47 AM
05/24/12 06:47 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Thanks guys but I don't have the deluxe seat belts. Seems like my setup is from a 73 car. Notice how the shoulder belt attaches to the bajonet of the lap belt? Just one buckle on the transmission tunnel side instead of two:
https://board.moparts.org/ubbthreads/show...amp;Search=true
and here:
http://www.dodgecharger.com/forum/index.php/topic,18596.0.html You need to copy/paste this link in order to get to the topic.
