Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: CompWedgeEngines] #1237816
05/23/12 04:09 PM
05/23/12 04:09 PM
Pick me Pick me! I could write several chapters!!!
My all time favorite were the guys that kept on breaking stock 302 blocks in their 10.5 tire Mustang with a hair dryer the size of a pizza on it--they WOULD NOT go with an aftermarket block--well....they brought in the latest build to dyno--first time they had done that --First hard pull under a TON of boost you could see the damper move about what looked like 1/2 inch as the entire deal flexed that much under load--it was eye popping ( and block popping) I have always remembered that when someone talks about crank flex etc
Roller cams will push forward enough to crack an aluminum waterpump housing--that is why most used ones are in the flea market. On a budget build I used to JB weld some valve spring shims in the gap after I had end play set like I wanted it then last year did one, went to the pits after a few passes to look in on how they were doing--leaned over and noticed my JB shim pack was gone! Use a good cover boys--it is a must with roller cams.
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: CompWedgeEngines] #1237817
05/23/12 05:39 PM
05/23/12 05:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont do engines for customers but do chassis work
(at least I did... I'm quitting it) and its nothing
but a PITA... from bounced checks... customers not
picking up...you name it... I can make more money
and quicker money tricking out golfcarts or just doing
fab work
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: Stanton] #1237818
05/24/12 02:19 PM
05/24/12 02:19 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Where can a person find one of those?
Promax sells a nice cast cover with seal for $100 but you'll need to add a pointer. It fits under the waterpump. You need to trim back the oil slinger if you're going to use one as it will rub the cover.
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: ZIPPY] #1237819
05/24/12 03:14 PM
05/24/12 03:14 PM
an8sec70cuda Offline
I've never used anything but a stock cover.
Same here.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: an8sec70cuda] #1237820
05/24/12 05:51 PM
05/24/12 05:51 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
thanks for deleting my post.guess when you not with the "in crowd" that happen's.
Re: BEST SEALING TIMING COVER FOR RB 440??? [Re: Jwilli500] #1237821
05/24/12 06:07 PM
05/24/12 06:07 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ok, I got the name wrong and can't remember who they were - they were at the Indy swapmeet. Anyhow, Muscle Motors sells the same one so try those guys. They were a few bucks more and didn't include the seal.
They're a nice piece. I drilled the hole and put the plug in so I could check cam end play. The cover is thick enough to tap.
