Re: BEST SEALING TIMING COVER FOR RB 440???
[Re: Labratt]
#1237797
05/22/12 07:34 PM
05/22/12 07:34 PM
Posts: 31,029 Oregon
AndyF
Yes, the cast covers will seal better than the tin covers. But some of the cast covers won't fit under a stock water pump, and some of them don't have a TDC pointer. So you have to pay attention to the details. My billet cover has an extra thick rail so it seals up very well, but it isn't "low budget". http://arengineering.com/products/timing-chain-cover/
Re: BEST SEALING TIMING COVER FOR RB 440??? *DELETED*
[Re: AndyF]
#1237798
05/22/12 08:05 PM
05/22/12 08:05 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Post deleted by Al_Alguire
RIP Monte Smith
[Re: CompWedgeEngines]
#1237799
05/22/12 08:23 PM
05/22/12 08:23 PM
Posts: 998 Clinton Township, Michigan
Dartin
Randy, as Andy mentioned some won't fit under a stock water pump without a spacer. I don't recall what balancer you are using, but ATI sells a specific one for the Indy cover. Competition Wedge, I have one of the stock covers on my "wall of shame"! Live and learn..... Randy
[Re: 440Jim]
#1237801
05/22/12 10:04 PM
05/22/12 10:04 PM
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
#1237802
05/22/12 10:57 PM
05/22/12 10:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your still solid cam however right?
Randy(LabRat) is also
[Re: MR_P_BODY]
#1237803
05/22/12 11:58 PM
05/22/12 11:58 PM
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
[Re: BradH]
#1237808
05/23/12 02:03 PM
05/23/12 02:03 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Then by all means spend the extra coin and get one...........
[Re: Thumperdart]
#1237809
05/23/12 02:17 PM
05/23/12 02:17 PM
BradH
...and my cam doesn`t budge w/a slightly pre-loaded rollerized button....
Isn't there supposed to be a minimal amount of free play between the button and the cover, rather than pre-loaded against it?
[Re: Labratt]
#1237811
05/23/12 02:56 PM
05/23/12 02:56 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
I've never used anything but a stock cover.
Rich H.
Esse Quam Videri
[Re: BradH]
#1237812
05/23/12 03:05 PM
05/23/12 03:05 PM
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
#1237813
05/23/12 03:41 PM
05/23/12 03:41 PM
ZIPPY
S.E. Michigan
Yes of course the timing cover flexes, but a stock type water pump housing does an admirable job at stopping it.
Of course this means dinking around for awhile, spending time on it, adding a piece of metal between the two parts that is just the right thickness to take up the space, without killing the clearance.
For a guy working out of the garage at home on a budget, where time is more plentiful than money....when the money spent might mean the difference between buying something more important he should absolutely spend the time dinking around with it and get it right, it will cost him next to nothing and he can set the cam end play wherever the heck he wants.
For a pro where time is money, whatever time you spend checking/correcting anything old is probably more expensive than the most expensive brand new part you could get...so anything old does not make sense from that perspective....in that situation stock timing cover is best used as a frisbee, or (preferably) give it away to one of us guys working at home in the garage.....
Rich H.
Esse Quam Videri
