Re: "The Mule"
[Re: MikeyT]
#1235820
06/10/12 12:15 AM
06/10/12 12:15 AM
Posts: 17,915 S.E. Michigan
ZIPPY
S.E. Michigan
Hi Mike Wasn't really planning on any dyno efforts or racing with it to be honest, as long as it feels good to drive I'm ok with it. But, if the big C body feels much better than expected, I might change my mind. We'll see. It ran 15s with the original 400 and some tuning, and in that particular car 15s was OK with me, until I wore out the motor and it felt lousy to drive. Just a cruiser ![](/ubbthreads/images/graemlins/wave.gif) She's holding 75psi oil pressure with a speed handle, I've got good oil flow upstairs, and I tried something new (for me), I pumped up the lifters while priming to see if they would hold oil. Seems ok so all systems are go. I'm going to try one other new thing also, I'm going to fire it up on the floor before the swap to make sure everything's cool.
Rich H.
Esse Quam Videri
Re: "The Mule"
[Re: ZIPPY]
#1235822
06/10/12 11:42 PM
06/10/12 11:42 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Hi Mike
Rich,
I'll be honest I was just curious to see what HP you could ring out of a good basic rebuild. I think you will find that you are pleasantly surprised by it. I know the XE268 is a little cam, but it worked well in my old 70 dodge with a good built 440 with better heads and headers, but that cam and 4040 lbs of B body were very close to the 12's at 107 MPH. It has a nice little raspy sound and works well with a heavy car.
Mike
1969 Dodge Dart Swinger
Re: "The Mule"
[Re: MikeyT]
#1235823
06/11/12 11:09 PM
06/11/12 11:09 PM
ZIPPY
S.E. Michigan
Got it fired up on the shop floor very briefly, couldn't run it for long because it was lacking a cooling system but I know the fuel pump works, it's got plenty of spark, the timing is somewhere close to where it needs to be, and so on. Temporarily rigged a cooling system and the rest, but now it's too late to fire it up/loud enough to wake the dead like any 440. Ah well, always tomorrow. I'm not proud of the whole rigged setup, but it only needs to run maybe 5 minutes at a time like this while I break in the cam. I like to do a 4 or 5 shorter break in sessions instead of one long one, so nothing gets too hot, lessens the chance of anything going haywire. It sounds pretty good through open 2" super comps ![](/ubbthreads/images/graemlins/smile.gif)
Rich H.
Esse Quam Videri
Re: "The Mule"
[Re: ZIPPY]
#1235824
06/11/12 11:13 PM
06/11/12 11:13 PM
ZIPPY
S.E. Michigan
Please note the highly complex and high tech ignition and oil pressure gauge mounting, using only the most expensive parts money can buy. Nothing is too good for the mule!
After it's run in for 20-30 minutes it's all coming back off anyway, so no big deal.
Rich H.
Esse Quam Videri
Re: "The Mule"
[Re: ZIPPY]
#1235825
06/12/12 01:16 AM
06/12/12 01:16 AM
MikeyT
Watertown, WI
I am sorry, its kind of cute sitting there, all innocent like that! I bet it makes the flour shake when you rap it a bit! ![](/ubbthreads/images/graemlins/thumbs.gif) Mike
Re: "The Mule"
[Re: Maximus_Wedges]
#1235827
06/12/12 09:41 AM
06/12/12 09:41 AM
ZIPPY
S.E. Michigan
It was loud enough to make the girl and kids run out of the house and come see what the heck was going on All three seemed a bit flabberghasted at the volume levels, it shook the whole shop. Probably would have been quieter outside, but I didn't feel like moving that whole redneck setup outdoors just to put it back inside a few minutes later. I was wearing hearing protection ![](/ubbthreads/images/graemlins/wink.gif) She'll be fired up again before dinner tonight. Since it has stock heads and I can get the lifters out without pulling anything but the valve covers/rockers, I might go the extra mile and do a visual inspection on the lifters before pronoucing it ready to swap in.
Rich H.
Esse Quam Videri
Re: "The Mule"
[Re: racer_amx]
#1235829
06/12/12 11:45 PM
06/12/12 11:45 PM
ZIPPY
S.E. Michigan
Made some more noise and wrapped up the cam break in a little before 9:00 tonight. It's got 25-30 minutes on it now.
It sounds good enough to where I think I will just run it, maintain it, keep the good/flat tappet compatible oil in it, and cross my fingers.
Did I mention I don't really even like flat tappet cams/lifters much anymore? If budget would have allowed and the whole thing were freshened up, I probably would have put a 268 solid street roller in it. But this was supposed to be a cheap once-over so I used what I already had on hand.
Rich H.
Esse Quam Videri
Re: "The Mule"
[Re: ZIPPY]
#1235830
06/13/12 12:09 AM
06/13/12 12:09 AM
ZIPPY
S.E. Michigan
Minor issues encountered...the float stuck on the holley and when I got that repaired, the lock screw gasket started leaking. I fixed that and then the crappy taiwan chrome POS fuel line started to drip. Eventually I gave up and just put rags on the intake to make it through the 20+ minutes. I don't even plan on using that carb, I'm going to use a different 3310 that has electric choke (cruiser theme). I thought this one with the air horn cut off was maybe a little fresher since I had used it more recently. Nope, wrong, guess again Rich ![](/ubbthreads/images/graemlins/eyes.gif) . One header bolt leaked water. Pipe dope. Other than that, not much of anything to report (which I'm glad about). Here's a link to a video of me throttling it a little and changing the rpm all around at the end of the cam run in. The noise at the beginning is an old metal box fan I put in front of the rad. http://s80.photobucket.com/albums/j180/zippy_05/?action=view¤t=MOV00704.mp4 Neither the carb or the timing are perfect, and the spark plugs are used ones from 2001 I left in there on purpose, anticipating carb issues. The old Holley did not disappoint me ![](/ubbthreads/images/graemlins/laugh2.gif) It's only going to get better from here. It's molson time ![](/ubbthreads/images/graemlins/beer.gif)
Rich H.
Esse Quam Videri
Re: "The Mule"
[Re: tboomer]
#1235834
09/16/12 10:52 PM
09/16/12 10:52 PM
ZIPPY
S.E. Michigan
Been awhile... My Dad got sick, and I lost him early in August I miss him more than I can describe ![](/ubbthreads/images/graemlins/engel016.gif) I'm sure alot of you guys can relate to that. It's taken me awhile to get my head screwed on straight again, but I'm almost there. Been trying to clear clutter out and get back to work on the car projects....it took me most of the weekend but I'm ready to finish what I started on the C body now Here's the happy recipient of the 440.
Rich H.
Esse Quam Videri
Re: "The Mule"
[Re: ZIPPY]
#1235835
09/16/12 10:54 PM
09/16/12 10:54 PM
ZIPPY
S.E. Michigan
Here's the dead soldier 400. Actually not quite dead, it fires right up but it's only got 3lbs of oil pressure, and a dead hole, certainly not much fun to drive....
Rich H.
Esse Quam Videri
Re: "The Mule"
[Re: ZIPPY]
#1235837
09/16/12 11:08 PM
09/16/12 11:08 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Very cool thread...been following it. And I am really sorry to hear about your Dad.
Re: "The Mule"
[Re: John Burdine]
#1235839
10/02/12 11:11 AM
10/02/12 11:11 AM
ZIPPY
S.E. Michigan
Thanks guys.
At times I wonder why I keep posting to this, but maybe later when the old "So and so is tired of reading about unstreetable zillion dollar engines he can't afford" discussion comes up, maybe it'll come in handy.
If nothing else it's adds to the therapy value for me, even though it is just a cheap rehash, what the heck.
I didn't know you could pull a stock big block out of a C body without taking off the hood until I tried it. A couple quick measurements showed it was possible, but I still had my doubts...it went nice and smooth.
Rich H.
Esse Quam Videri
