Re: try to win or go fast?
[Re: vttm]
#1233663
05/15/12 01:23 PM
05/15/12 01:23 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
If you could make both days there is a test and tune saturday.
Man I wish! some day when the kids are older I might be able to go 2 days in a row... I'll just try and run it the same both times. Last time I went I ran 2 classes and made the semi's in both. That'd be fun
[Re: Mr.Yuck]
#1233664
05/15/12 01:32 PM
05/15/12 01:32 PM
Posts: 7,506 Az
Crizila
Az
In my case, go rounds. I have back to back night races this weekend and I am presently sitting 14th in points ( out of apperox 60 ). Really want to finish in the top 10 this year. It's going to boil down to mostly driver consistency. Where did my wife put my practice tree !!
Fastest 300
[Re: jamesc]
#1233668
05/15/12 02:20 PM
05/15/12 02:20 PM
Mr.Yuck
Brookeville, Md
umm...why not do both? hammer it both runs then put a number on it
ahh that is a good question and I probably should have mentioned that the car should run 11.20's (I hope) and I have no cage. I don't want to have nice back to back runs and be told to slow it down for elmins with no chance to run. If I could bet on 3 runs I'd run the 1st 100% and try something else for the other 2.
[Re: dragram440]
#1233671
05/15/12 03:05 PM
05/15/12 03:05 PM
Mr.Yuck
Brookeville, Md
Sounds like you need to get a cage in it asap! Unless you plan on not running it for long with this setup. That would drive me crazy not being able to run it all out all the time.
no cage, at least not anytime soon. Kids have to be able to climb in and out.
[Re: Thumperdart]
#1233674
05/15/12 05:22 PM
05/15/12 05:22 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I always run the car flat out and see how fast it is running that day. Then I dail right at my fastest et and try to cut a good lite and win. My car is usually pretty consisdent and I figure it will run within a few hundreths of my best et. So if I cut a bad lite I will loose anyway. But if I have them covered in eliminations I will hit the brake and slow it down. Good luck as I want to go but dont know if I can make it. Ron
[Re: Cab_Burge]
#1233676
05/15/12 07:32 PM
05/15/12 07:32 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
If you don't try to make it as fastest as you can how will you know what to dial The key to constintcy is traction and repeating the same starting line RPM (with no tire spin)and shifting it out of 1st and 2nd gear at the same RPM and not lifting during time trials Getting the best reaction times is another story Don't forget Have fun
I provide a quality car and make decisions on the numbers. My driver ( and the woman who tolerates all my nonsense and has for 35 years ) is responsible for the routine , which she is very good at. The new car might be a different story , but at the end of the day , I try to take the most important piece of advice you offer...I have fun. If I could cut a light to save my life , it would be a lot more fun......
