Re: Nitrous tune question [Re: MoparBilly] #1231939
05/14/12 01:46 AM
05/14/12 01:46 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I know this is no big deal when you are talking about pulling just few degrees of timing out with a retard box, but the more you pull out, the further out of phase the rotor and cap are. Back when I was hitting the Challenger with 2 systems, I was pulling 9 at the hit and 6 more on the second.Crank trigger, so I phased it for the retard.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Nitrous tune question [Re: turner] #1231940
05/14/12 07:11 AM
05/14/12 07:11 AM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
Thanks all for the time you took to help, I will try to contact a few of the mentioned people and get some opinions and additional support. I will be at a bracket race here in Michigan on Memorial day and intend on making some NOS time trials, I know that my 10 second pass is a sure thing!
Keep the info coming
What MSD unit can I buy to adjust my timing with the retard pills, I have the 6al....If im going to be doing alot of timing changes this seems the only way to go
Save yourself the headachs and get a dital 6 plus box or a programable 6 clean and easy to use.
Re: Nitrous tune question [Re: MoparBilly] #1231941
05/14/12 08:38 AM
05/14/12 08:38 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
I tend to jet for a fat tune-up, that way when the t-d line from my carter mechanical starts running out of pressure at 900ft, I can still make the finish line with the spark-plugs and head gaskets intact.
A guy would think you'd just put a fuel pump on it???
If you can't handle the truth, you're living a lie.......
Re: Nitrous tune question [Re: Big Squeeze] #1231942
05/14/12 01:37 PM
05/14/12 01:37 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
That would spook even me seeing the fuel pump start to give out way too early, I run one big pump for the six pack and the plate kit at 100, then one seperate same type pump for the fogger system for another 250.
Re: Nitrous tune question [Re: Big Squeeze] #1231943
05/14/12 11:48 PM
05/14/12 11:48 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Head gaskets are cheaper than a good fuel pump...
Re: Nitrous tune question [Re: MoparBilly] #1231944
05/15/12 08:37 AM
05/15/12 08:37 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
lol....so, what you're saying is you have a lot of free time on your hands??
Re: Nitrous tune question [Re: Big Squeeze] #1231945
05/18/12 09:55 PM
05/18/12 09:55 PM
metro detroit
turner Offline OP
turner  Offline OP
metro detroit
I talked to Monte today and he gave me some jet recomendations and a tune to start with....I have in my super powershot nitrous kit six jets 47-53-55-61-63-71, I was told by Monte to start with the following tune (without buying additional jets) 55N/47F, 30 degrees timing, and 5 lbs fuel pressure.
Robx, Leon, Big Squeeze based on me and Montes conversation you were all correct in one way or another, thanks for the help
