Re: why a 4 prong balast? [Re: Mr.Yuck] #123022
09/22/08 12:04 PM
09/22/08 12:04 PM
Virginia
67 GTX Offline
67 GTX  Offline
Virginia
You will also have two field wires for your alternator hook up if this is a Year One harness with the electronic conversion. Just a heads up when you get to that point. I went ahead and went to a two field alternator and a 4 prong ballast on my 67 GTX when I used this harness. The later alternator is supposed to be better.
Re: why a 4 prong balast? [Re: 67 GTX] #123023
09/22/08 12:09 PM
09/22/08 12:09 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Yeah I plan on using a dual field Alt..
Re: why a 4 prong balast? [Re: 67 GTX] #123024
09/22/08 08:05 PM
09/22/08 08:05 PM
Missouri, U.S.A.
JSSuperbee Offline
JSSuperbee  Offline
Missouri, U.S.A.
I too have the Year One conversion you refer to. I purchased a black regulator that is supposed to be compatible with this set up yet retains the look of the original regulator. However, the conversion harness has a push on triangular shaped connector for the '70 and later type regulators. What did you do about this situation?
James Stinebaker
Re: why a 4 prong balast? [Re: JSSuperbee] #123025
09/22/08 08:23 PM
09/22/08 08:23 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I haven't gotten it yet, should be here in a day or two. I think my regulator has the triangle shaped socket.
Re: why a 4 prong balast? [Re: 383man] #123026
09/22/08 08:29 PM
09/22/08 08:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I have never seen a dummy 5th pin in my life as all the ECU's I have seen in the last 20 years are all 4 pins. Ron
Check out www.napaonline.com
5 pin ECU is available, dunno if it is indeed a dummy fifth pin or not. Only one way to tell.
Don't be the exception.
Re: why a 4 prong balast? [Re: Supercuda] #123027
09/22/08 11:05 PM
09/22/08 11:05 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I guess what I mean is I just dont see anyone selling the 5 pin ECU's around here as you just dont need it. It's always the 4 pin that the parts stores sell around here and of cousre the MP are all 4 pin. But since you can use the 4 pin ECU on any of the 4 or 5 pin wired cars it kinda makes sense to only sell the 4 pin ECU's. Ron
Re: why a 4 prong balast? [Re: Supercuda] #123028
09/23/08 07:54 PM
09/23/08 07:54 PM
CT - just outside Hartford
Crazy73 Offline
Crazy73  Offline
Tongue test!
Pete
-1968 Barracuda 4spd 383-6pk
