Re: Brake Bias and matching parts
[Re: PHJ426]
#1229777
05/08/12 10:24 PM
05/08/12 10:24 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I would definitely try it first before buying and plumbing the adjuster. You might be pleasantly surprised.
Mopar to the bone!!!
[Re: 72Swinger]
#1229780
05/09/12 02:14 AM
05/09/12 02:14 AM
Posts: 31,115 Oregon
AndyF
Yes, that could very well be true. Brake bias is pretty complicated to figure out on a disc/drum car. It is probably easier to just try it and see how it works and then adjust from there. Brake pad compound is another variable that can be tweaked. Ride height, weight distribution, tire size, etc. also play a part.
If you never drive the car in the rain then you can get away with a lot more rear bias. If you do drive the car in the rain then you have to set it up for heavy front bias so you don't spin the car during a panic stop in the rain. But setting the car up that way kills a bunch of the stopping distance since the rear brakes are just along for the ride on dry pavement.
[Re: PHJ426]
#1229788
05/10/12 12:34 AM
05/10/12 12:34 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Briefly....
> Getting the proportioning spot-on is a real key to reducing stopping distances. All the OEM stuff, '60s/'70s, was a huge compromise.
> Having said that....front disc/rear drum is a moving target. The Duo-Servo brakes (rear drums) are SO non-linear, its crazy.
> Having said that, you can still make a huge improvement over stock with an adjustable valve. Remember: the fronts should always lock first! (Fronts locked = no steering, but car can go straight. Rears locked = SURE spin!)
Rick
