Re: Oil preasure / Vacume pump question
[Re: WH23H6]
#1228903
05/08/12 05:43 PM
05/08/12 05:43 PM
Posts: 5,875 communist bloc of new jersey
jamesc
Its the MP Mega block....stage 5 millenium heads....would putting a breather on the opposite valve cover just not defeat the purpose of the Vacume pump? I can't help but think is got to be a leak on the suction side of the oil pick up somewhere were in the vacume area... I took off the pan and pickup last night...couldnt see anything....the o-rings between the pickup and pan where nice and tight....All I know for sure is Im not nuts ! Its happening....
imho i agree putting a breather on the engine would not be the proper solution not to mention the greater chance of pulling oil out of the engine. vacuum pumps are supposed to pull gasses out of the engine not through it. i agree it would seem most likely there's a problem on the suction side of the oil system, or with the system in general. there are a lot of people running vacuum pumps without this issue. with regards to the pickup you would "expect" the entire pickup assembly to be submerged which should keep any leak there from causing a problem. although if there's a lot of oil in suspension the block portion might come uncovered.
this is one of those things that's frustrating for people trying to help because of not being there first hand.
i would think the possibilities are a vacuum leak on the suction side, oil staying suspended in the engine for some reason, or maybe really loose pump clearances...or maybe a combination of the above.
i know it's a stretch but any chance you have access to a couple -12 caps and could cap off one of the suction lines? if you were to do this it might identify a problem in one line or the other. one would think a visual inspection as you've done would expose any problems with the suction side. have all the O-rings on the pump and pickup fittings been inspected, i guess this would include the relief whatever you have in there.
[Re: AndyF]
#1228909
05/09/12 12:17 AM
05/09/12 12:17 AM
jamesc
Yes, sucking the line closed would do the same thing. That is another good theory on what is going on.
i am by no means ruling this out because it is a potential problem though he said he already renewed the lines. not that doing that would correct the problem. i was under the impression that the vacuum rating of this type of hose was marginal but this is what Aeroquip says of their hose...
The Performance Industry’s most popular racing hose.Stainless steel outer cover for excellent abrasion resistance. Excellent pressure rating (1,000 PSI from -04 to -12. AQP elastomer smooth bore inner tube. -45 to +300 F temperature rating, full vacuum (-10,-12,-16). Approved with reusable and crimp fittings. Applications include fuel, lube, coolant, air.
i read this as full vacuum in the -10, 12 and 16 sizes and we're no where near full vacuum.
i know it's really reaching but one thing i was thinking i might try if it was me (because it sounds like he's done most of the normal checks) would be to use a regulator and pressurize the engine. you would have to be VERY careful doing this and it may be an exorcise in futility but it might show a suction side leak if there is one.
one thing's for sure when he gets it resolved people need to know what it was.
[Re: jamesc]
#1228910
05/09/12 12:39 AM
05/09/12 12:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Myself I would pull the swinging pick up out and install a braided line where the pick up mounts to the pan and just lay the end of the line on the bottom of the pan... just to eliminate the pick up... seen too many of them have O-ring problems and didnt like to prime
[Re: jamesc]
#1228911
05/09/12 12:46 AM
05/09/12 12:46 AM
Posts: 134 Closest Race Track
WH23H6
Closest Race Track
Ok guys.... first of all thank you very much for all of your input...its nice to have a forum like this to discuss these types of issues that can cause us grief....this forum is perhaps the best tool we all have in our shops....let me tell you what I found...after removing the oil pan and checking all of the "hard" things.. I decided to do volume check on my custom 10 quart oil pan...it seems that at 10 quarts the level in the pan was just above the 2 out let holes for the Milodon pickup....after looking at it and assuming that even at idle...(1200rpm) at least 2 to 3 quarts of oil would be in motion in the engine...droping the level these 2 or 3 quarts would drop the level below the point where the swinging pickup attaches to the billit holding block...the swinging pickup is not O ringed...much to my suprise! I reassembled things and put 13 quarts in the pan...allowing for 1 quart in the remote filter and lines, 2 to 3 quarts in the engine while running.....problem solved! Vacume pump hooked up...idling at 1200...now have constant 85lbs preasure...
I bought the car last year and ran 10 quarts in it all year on the reccomondation of the previous owner...never had an issue...all of this only came to light after the winters changes...(Vacume pump)...thank god it happened in the shop at an idle and not on the back bumper at 7000rpm!!!
Seems the simplest things...as usual...are the ones that drive me nuts...
Thanks again guys (and gals!)...see you all on the track!!
[Re: MR_P_BODY]
#1228913
05/09/12 01:01 AM
05/09/12 01:01 AM
WH23H6
Closest Race Track
So what is leaking at that point where it attaches to the pan
I think it was where the swinging pickup attaches to the holder that bolts to the pan...there is no O ring...only a cottor pin that allows it to swing...when this got below the oil level it must have allowed the crankcase vacume to pull there and cause the pump its issues....keeping more oil in the pan and keeping this point covered seems to have corrected it...
[Re: MR_P_BODY]
#1228915
05/09/12 01:13 AM
05/09/12 01:13 AM
WH23H6
Closest Race Track
tQuote:
thats where the O-ring is suppose to be(I believe)... you better look into that... cant run with just 3 qt useable oil... with the bit of pressure you had in the crank case it maintained a seal (before the vac pump)
I dont think it ever had an O ring...the groove in the pickup is just big enoungh for the cottor pin to allow the swinging motion...putting an O ring in this groove would stop the swinging motion...kind of a piss poor design by Milodon if you ask me...but whatever....I think they should have double grooved it and had an O ring as well...
[Re: WH23H6]
#1228916
05/09/12 01:35 AM
05/09/12 01:35 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
It makes sense that no o-ring where you describe would cause a problem. With the engine sealed up, applying a vacuum to the crank case area will do 2 basic things. (1) Vacuum in the oil pan area would make it harder to pull oil through the oil pump intake system, be it just a conventional pickup tube or a swinging pickup, resulting in a loss of pressure. Even properly sealed it would be harder to get oil into the pump - unsealed it would just suck air and not make pressure. (2) On the pressure side of the oil system, everywhere that oil is usually forced out under pressure (bearings, lifters, rocker arms, etc.) will also have vacuum trying to pull the oil out, also resulting in loss of oil pressure. Pretty much every vacuum system I've seen has shown some oil pressure loss on back to back belt on/off testing.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1228917
05/09/12 01:42 AM
05/09/12 01:42 AM
MR_P_BODY
Your correct that it will be a bit lower in oil pressure... 2 inch of merc is 1 psi so with 11" of vac thats 4.5 psi lower... big deal... but with the vac on the rings they seal better and end up making 20-45 more HP
[Re: MR_P_BODY]
#1228918
05/09/12 01:56 AM
05/09/12 01:56 AM
Evil Spirit
Newport, Mi
Yep - not knocking the need for the vacuum system, Raff - just trying to shed a little light on why the system can affect oil pressure.
[Re: Evil Spirit]
#1228919
05/09/12 02:22 AM
05/09/12 02:22 AM
jamesc
and afaik you would be correct. when i first dealt with these things i questioned that wisdom. a seal makes it drag, without it there's a potential leak. like i mentioned one concern i had was if any portion of the PU became unsubmerged and it sounds like it did.
great to hear the problem is solved
[Re: dvw]
#1228921
05/10/12 06:56 PM
05/10/12 06:56 PM
MR_P_BODY
The one swinging BB pick up I had years ago had a O ring in it(dont recall who the manufacture was) but it was a bit snug and I thought it didnt swing well but at least it didnt suck in air
