Re: ALTERKATION HATED BY MOPAR ACTION??
[Re: Kern Dog]
#1228647
05/07/12 06:17 PM
05/07/12 06:17 PM
Posts: 11,080 Berlin, N.J.
abodyjoe
Berlin, N.J.
I'll add that I also agree that the means RMS used to eliminate bump steer seemed odd. Rick referred to it as a "cantilevered" design. In smoothe surfaces, the design probably works fine. Imagine taking it on the neglected roads that we drive on every day. The dips, cracks, ruts and potholes would certainly take a toll.
my alter-k has been in my dart since july of 2006. its all crappy pot hole (should see my road. wish they would fix the damn thing soon) dip all over south jersey/pa roads driven. system has held up fine. all original heim joints and all. i grease everything every spring while i'm checking the car over for the summer season. if it wasn't a 80 mile round trip for work or gas was $1 a gallon again i would daily drive the car. no doubts in my mind that the system would hold up to daily abuse. only issue i have is that the paint i used on it when it was new is falling the hell off. that pisses me off..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: Jim_Lusk]
#1228651
05/07/12 09:38 PM
05/07/12 09:38 PM
Posts: 43,599 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I have driven several cars with the Alter-K and the Mr. Norms design plus a few other of the designs, and all were based off the Alter-K except the Magnum Force. I have been over 150 MPH and through the twisties a few times at speed and my opinion is the Alter-K is the best. Yes there is some bump steer with some of the designs, but the Alter-K seems to have the least IMHO. The main difference between stock k-frames and Alter-K types are the removal of the torsion bars and addition of coil overs, less weight, better brakes, plus rack and pinion steering. I do agree that the unibody was not designed for the loads on the shock towers that the coil overs have and to be honest tying the frames and gusseting the shock towers should be done if the car is to be street driven alot. Son't forget the infinite adjustability of the new suspensions to your taste, while the stock suspensions are very limited.
JB Rhinehart, Realist
A-Body's RULE!
[Re: savoy64]
#1228653
05/07/12 10:04 PM
05/07/12 10:04 PM
I totally agree with Rick on all the points he made.
However...
Rick is all about making things "bomb proof" and I can see where the RMS may have it's shortcoming in an application that sees thousands of street miles in all conditions.
The factory Mopar design is very hard to improve upon when you think about it in that application.
If you're after weight reduction and something that free's up space for headers in a drag-type application then the RMS K is your ticket.
I thought he was very fair in his analogy.
[Re: savoy64]
#1228654
05/07/12 10:25 PM
05/07/12 10:25 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I have looked at the Alterk kit for my street/strip Dart. It's a very nice set up for sure, but honestly I think my money is better spent elsewhere. As it's set up now it runs high 1.30 60' foot range. I run skinnies up front with Cal-Tracs and monos on the rear so it's set up more to go in a straight line. That being said it doesn't handle bad and is very predictable in the curves. The only front end upgrades I'm looking at now is a set of adjustable upper control arms with heim ends and adjustable strut rods. The car already has Strange disk on the front, Wilwoods on the rear and will stop on a dime. Nice front end set up, but not worth the $$$ to me. I like to see more return for the investment on the parts I buy. .
[Re: cudaboone]
#1228658
05/07/12 10:50 PM
05/07/12 10:50 PM
abodyjoe
Berlin, N.J.
Did not mean to start a firestorm. I just feel that if you knock something, you should have some facts to back up any and all of your statements. It's no different that any other scientific or professional statement. You have to have data to back them up good or bad. Expecially when it is someone's business/livelyhood. Hated might have been a little harsh, but he did seem to zero in on alterkation. If i do get one, it looks like a will have to come up with a way to beef up the frame. It looks enticing when you think of the room you will gain.
its a lot more enticing if you have ever driven a car with one. i'm working on selling a few thing and saving so i can buy a second one to install in jamies dart.
[Re: RodStRace]
#1228662
05/08/12 12:27 AM
05/08/12 12:27 AM
Slant, while I don't have the heavy background to give either design the nod, I will say that your example is a simplification. By that measure, a straight axle is great!
..if you're into Conestoga's.
