Re: Carb Tuning with 02 sensor?
[Re: 6bblFLASH]
#1227750
05/06/12 01:00 PM
05/06/12 01:00 PM
Posts: 43,913 Bend,OR USA
Cab_Burge
swapped out carb for a borrowed CarbShop 950 and the problem is GONE!!!!
With the same jetting as before it is now 11.2-5 at max throttle. Fuel pressure is still at 5.5. Noticable increase in power,pulls in high pretty darn good. Odd thing is I lost 1-lb. of boost???? Went from 5.5 to 4.5????? Less cfm.??????
Your to rich still, try going to 12.2 to 13.0 at WOT, jet down a LITTLE(one jet size on all four corners) at a time Look at the spark plugs after each jet change, BTW what plug name and heat range are you using now? Get ready for massive tire spin, if you don't already have it the difference in power between 11.2 to 12.5 AFR is tremendous
[Re: mopar dave]
#1227753
05/06/12 02:53 PM
05/06/12 02:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have been told in the past peak power would be found between 12.8 and 13.2, but last time at track car was fastest at 12.5.
There is NO set number ... jet to the fastest MPH
[Re: mopar dave]
#1227755
05/06/12 05:18 PM
05/06/12 05:18 PM
Thumperdart
State of confusion
Although different fuels make max hp w/different afr`s...........
[Re: MR_P_BODY]
#1227757
05/06/12 09:48 PM
05/06/12 09:48 PM
Posts: 1,632 Lubbock,TX
DavidDean
Lubbock,TX
This has been my experience too.So many varibles such as collectors or header primarys which might pull in some air during exhaust pulses. My stuff usually wants numbers that are leaner.
[Re: mopar dave]
#1227758
05/06/12 10:18 PM
05/06/12 10:18 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I was using mobil premium at the time.
Your ideal mixture will probably be closer to 12.2 to one for max power with pump gas. It depends on the manufacturer,but that is a good starting point for low/non ethanol pump premium in my testing.
