Re: 4 speed shifter ID help needed [Re: biginchmotor] #1227709
05/06/12 08:11 PM
05/06/12 08:11 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Not a hurst , at least not one I have ever seen. Do it even have a reverse lockout ?
Re: 4 speed shifter ID help needed [Re: JohnRR] #1227710
05/06/12 08:12 PM
05/06/12 08:12 PM
Connecticut
biginchmotor Offline OP
Connecticut
There is no reverse lock out on the mechanism or handle.
Re: 4 speed shifter ID help needed [Re: biginchmotor] #1227711
05/06/12 08:49 PM
05/06/12 08:49 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
Only ones with that style handle (three bolt flange) are three speed units.
Possibly the third(?) arm is for the column interlock? Did e bodies use that?
All the ones I have seen are A body.
And not a Hurst.
It takes gasoline to interest me.
Re: 4 speed shifter ID help needed [Re: VL21] #1227712
05/06/12 09:22 PM
05/06/12 09:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
And not a Hurst.
Column interlock from shifter was 1970 only all cars (A/B/E...)
Sure looks like a 3 spd handle and ball. But I'm not very versed on manual trans stuff.
Re: 4 speed shifter ID help needed [Re: autoxcuda] #1227713
05/07/12 12:12 AM
05/07/12 12:12 AM
MN
astrobuf Offline
astrobuf  Offline
MN
I have a 71 Challenger w a 3speed. The shifter looks exactly like mine, but for the extra arm. I'm guessing as posted that this is a '70 3sp shifter from an E body.
Astrobuf
So, are you really a Rocket Scientist?
Re: 4 speed shifter ID help needed [Re: astrobuf] #1227714
05/07/12 01:21 AM
05/07/12 01:21 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Definitely an Inland (same shape of housing as 66 Inland four speed shifter).
