Difficult shifting in to and out of reverse, A-833
#12268
06/01/04 04:33 PM
06/01/04 04:33 PM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
I recently rebuilt my transmission, and it shifts great in every gear except reverse. Very difficult to get it in to and out of reverse. At first, it seemed like I had the wrong lever on the trans end, and it was going too far forward. I changed the lever out to make the lever more vertical, and it’s better, but still really tough. The shifter is adjusted per the FSM procedure, and it’s no trouble getting the shifter in to the reverse position. It’s just moving it forward and back that’s tough. Any thoughts? Clair
Re: Difficult shifting in to and out of reverse, A-833
[Re: 4speeds4me]
#12270
06/01/04 07:22 PM
06/01/04 07:22 PM
Mine too.. I have to get "tough" w/ the shifter to get reverse. Coming out to another gear is fine. I wonder if the levers in the shifter body are not lined up exactly right??
#12271
06/01/04 07:41 PM
06/01/04 07:41 PM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
I think Clair's got that covered. The way I read it it's not getting the reverse gate that's the problem, but the actual engaging/disengaging of the gear.
My Verti-Gate obviously has NO other portion of the shifter to be concerned with here, and it's easily twice the pull of the other gears...
2 Demons...no, not my kids!
[Re: 8_Barrel]
#12274
06/01/04 11:27 PM
06/01/04 11:27 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Ok Spill it 8 Barrel,
My GTS is a bear to put in reverse. Everything else is smooth as silk. I have the Pre-70 setup in mine.
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: Clair_Davis]
#12275
06/01/04 11:32 PM
06/01/04 11:32 PM
Posts: 823 On the open road
Hrtbkr
On the open road
I'm no expert, but here's how I solved the same problem I had with my car. Loosen all the side cover bolts and pry the cover towards the top of the transmission. Tighten the bolts back down while still prying up.
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
Re: reverse detent adjustment A-833 per 68 Ply FSM..
[Re: 8_Barrel]
#12279
06/02/04 07:01 AM
06/02/04 07:01 AM
GTSDave
I always thought it was because on a big block a body the reverse rod runs underneath the cross member. Makes for a funny angle.
-Dave
[Re: GTSDave]
#12280
06/02/04 09:34 AM
06/02/04 09:34 AM
Posts: 43,615 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
I have the exact opposite problem. Reverse is easy to go in and out of, but downshifting binds. If I just come out of fourth into neutral, I cannot get the trans into any gear without finally wrestling the shifter handle until something grinds. If I downshift from fourth to third, third to second, then first, everything works good. Also works that way from third to neutral. Any ideas?
JB Rhinehart, Realist
A-Body's RULE!
[Re: Clair_Davis]
#12281
06/02/04 09:46 AM
06/02/04 09:46 AM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
I've had the same trouble from time to time. Most times I was able to reposition the side cover. If you losen the cover slightly, can you re-position it upward to give more clearance for the reverse lock-out? It sound like it is hitting or rubbing the reverse lever in the transmission.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: Clair_Davis]
#12283
06/02/04 10:44 AM
06/02/04 10:44 AM
Posts: 10,755 North Dakota
6PakBee
North Dakota
Just a comment, I never had much luck finding the 'A' and 'B' interlock levers that 8_Barrell references. If the clearance is to the point that there is no drag, I don't worry much about it. In the cases where there is too much interference and getting into reverse is a pain, a little judicious grinding on the reverse fork interlock cam will take care of the problem. Just my 0.02.
Rhinodart, sounds like you have too much shifter fork travel. The one transmission I had that did this on the 3-4 shift was caused by the fork overtravelling the slider gear. This allowed the synchronizer slippers to pop up a little on the neutral side of the slider gear and prevent the gear from returning to neutral without a lot of effort.
[Re: 4speeds4me]
#12285
06/02/04 03:42 PM
06/02/04 03:42 PM
6PakBee
North Dakota
Guilty as charged!! Unfortunately the Inland units don't have such animals. God I love GM!
