Re: Running hot and running out of ideas 67 Belvedere
[Re: Belvedere1]
#1226280
05/03/12 12:07 PM
05/03/12 12:07 PM
Posts: 5,161 CT
GTX MATT
CT
Hook the vacuum advance up, I bet it runs cool
[Re: GTX MATT]
#1226281
05/03/12 12:13 PM
05/03/12 12:13 PM
Challenger 1
Cincinnati, Ohio
Yup, why isn't it hooked up?
welding up the slots to limit timing is not locking it out, I think your confused on that point.
Why happens to your timing when you you have a timing light on it and you rev it up?
[Re: ThermoQuad]
#1226285
05/03/12 03:02 PM
05/03/12 03:02 PM
Challenger 1
Cincinnati, Ohio
220 degrees is warm, it is not hot.
Your thermostat opening temp is too low. Opening Temp has nothing to do with operating temp except to keep engine above a specified temp.
Disconnect the radiator trans cooler and just run the external one. No need in the southwest for the radiator trans cooler.
Today's fuel requires a 195 degree thermostat.
Do not use water wetter-causes issues if left in too long.
60% water, 40 % antifreeze, bottle of "be cool"
Use the viscous fan and a thermostatic fan clutch, do not use direct drive or any aftermarket fan. It's in the book-the mopar book. I did not make this up. I think mother Mopar's Larry Shepard might have a clue so be careful with advice you get from the internet.
Your radiator core is suspect-the center tubes are probably restricted, so some diagnosis with IR temp gun will tell you everything you need to know before throwing mud at the wall. Cheap ones are at China Freight.
Did you read the part about the thermostat??? that's not an old wives tale.
[Re: Reggie]
#1226286
05/03/12 03:24 PM
05/03/12 03:24 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
The fan clutch is sitting 7/8" - 1" away from the radiator and using a factory shroud.
That might be the problem. The fan should sit out enough from the edge of the shroud to pull cool through the radiator. Otherwise you're just blowing hot air around inside the shroud instead of pulling cool air through the radiator.
The blades of the fan shroud be 1/2 in the shroud, 1/2 out of the shroud
Optimum fan to shroud total clearance is 10% of the shroud's diameter. The total clearance is both sides of the fan. So... 20" fan shroud should have 2" of total clearance. And that will be 1" on both sides of the fan.
[Re: WheelsUp73]
#1226288
05/03/12 04:59 PM
05/03/12 04:59 PM
Posts: 1,261 Phoenix, AZ
Belvedere1
Phoenix, AZ
What is the wives tale on t-stats, I dont have the book??
[Re: ThermoQuad]
#1226289
05/03/12 05:28 PM
05/03/12 05:28 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
I think the words "MIGHT HAVE" should be changed to "SOMETIMES HAS" in this sentence ...
[Re: JohnRR]
#1226290
05/03/12 06:11 PM
05/03/12 06:11 PM
Posts: 5,895 Athens, Greece
Pyper70
Athens, Greece
I'll poke at this one only because it happened to my Dart once...My water temp was hitting 220 down the road...weird for a Slant 6 to have that happen. Everything was in tip top shape. I checked my Trans dipstick and I was a little low. I topped off the trans and got back to business as usual. I can only assume that the trans overheats and since it is aluminum and mated through a bell housing, you are heating up the coolant from the transmission side.
Have you run an A/F meter on it? make sure you have the right numbers through your powerband. The idle circuit is pointless...our cars don't sit at idle most of the time... you have to get out there to test and tune.
Not to hijack the thread but I have a 440, AC pump, factory cast iron housing and cast pump. 10:1, Eddy heads, Dual 500cfm Carbs. 26inch 4 core radiator, tranny cooler, 7-blade with viscous, 180º Napa stat (Mr Gasket are trash, bad QA). I even threw in Water Wetter. I know I have some test and tune because I just got my RPM heads on but I hit 180º driving down the road and 195º in traffic.
I have no vacuum advance. Its a mechanical dizzy. Are you sure your dizzy is setup correctly?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Belvedere1]
#1226292
05/03/12 07:22 PM
05/03/12 07:22 PM
Posts: 5,161 CT
GTX MATT
CT
It sounds like it probably it, but you should still run the vacuum advance. Just give it a try and see if it stops overheating.
[Re: Belvedere1]
#1226293
05/03/12 07:46 PM
05/03/12 07:46 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You've spent a lot of money on this car. Now go spend $39 dollars for a tool.
Go to Harbor Freight and buy an IR temp gun. Get the car up to temperature. Measure the temperature of the water neck. Measure the temperature of the radiator where the upper hose goes in. It should be very close to the temp of the water neck, assuming the thermostat is open. Measure the radiator where the lower hose goes out. There should be a minimum of 30 degrees temperature drop in the radiator. If not, measure the temp of the radiator core in a grid. Measure every couple inches across the top of the core. Drop two inches and measure across again. Repeat until you've measured the whole core.
The temp drop should be gradual. If you have any cold spots the core is plugged.
[Re: Belvedere1]
#1226295
05/04/12 12:20 AM
05/04/12 12:20 AM
feets
Senior Management
Senior Management
Irving, TX
http://www.harborfreight.com/non-contact-laser-thermometer-96451.html$39.99. Sure, there may be better units out there but what you're looking for is a noticeable change in temperature. When my Imperial had a clogged radiator there were areas where the temperature dropped almost 50 degrees lower than surrounding bits of the radiator.
[Re: Belvedere1]
#1226297
05/04/12 12:33 AM
05/04/12 12:33 AM
feets
Senior Management
Senior Management
Irving, TX
Before you start changing parts, grab the temp gun and check things out.
Putting a little distance between the trans cooler and radiator may help a wee bit. I'm not a fan of attaching things to the radiator core.
