Re: WideBand 02 Results
[Re: dmking]
#1225612
07/26/12 07:52 PM
07/26/12 07:52 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Well I`ve finally made enough headway to leave it alone for a while. Ended up with IFR`s @ .033 AFR`s @ .076 13.5 idle 13.5 cruise
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#1225613
07/26/12 10:54 PM
07/26/12 10:54 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
You started with your cruise A/F at 11.7--12.2 and now you are at 13.5. Nice job!!
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1225614
07/27/12 05:34 PM
07/27/12 05:34 PM
6bblFLASH
N.E. Ohio
Thanks,once I understood the pattern of the changes it started getting easier.
Going to check fuel mileage soon. Got 10.5mpg originally.
[Re: Thumperdart]
#1225616
07/28/12 01:05 AM
07/28/12 01:05 AM
6bblFLASH
N.E. Ohio
So what exactly did you tweek in the carb to dial in the cruise?
As delivered it had .070 AFR`s and .040? IFR`s Tried lots of combos and basically realized that if the idle circuit is maxed-out at idle,it can`t get much richer at cruise. Tried small changes to both IFR`s and AFR`s till it almost isn`t enough fuel to idle cold.Also lowered the primary float to just below the hole. That go me the 13.5 cruise. I expect mileage to be 13mpg or so. Got 10.5 @11.7/12.2 AFR,,,,,11.98 @ 12.5/7 AFR. Hope 13.5 yeilds a 13+. ![](/ubbthreads/images/graemlins/luck.gif)
