Re: WideBand 02 Results [Re: Dabee] #1225610
05/03/12 02:52 PM
05/03/12 02:52 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
i'm very interested in this topic. i want to put o2 sensors on my Challenger but funds are limiting what i can install. don't want to hijack here so i'm not gonna start asking all kinds of questions. but i am very interested in reading about what you did with you tuning. keep us posted.
Re: WideBand 02 Results [Re: joelson6] #1225611
05/03/12 05:31 PM
05/03/12 05:31 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
the above chart was from my first time with the wideband in the car instead of my big ninja.
in one pass it showed me that the accelerator pump needed a bit more fuel and the hood scoop was making my car go rich above 100mph.
like everyone says jet for best preformance at the track and just shoot for that number.
Re: WideBand 02 Results [Re: dmking] #1225612
07/26/12 07:52 PM
07/26/12 07:52 PM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Well I`ve finally made enough headway to leave it alone for a while.
Ended up with IFR`s @ .033
AFR`s @ .076
13.5 idle
13.5 cruise
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: WideBand 02 Results [Re: 6bblFLASH] #1225613
07/26/12 10:54 PM
07/26/12 10:54 PM
Indiana
Y
YO7_A66 Online content
YO7_A66  Online Content
Y
Indiana
You started with your cruise A/F at 11.7--12.2 and now you are at 13.5. Nice job!!
Re: WideBand 02 Results [Re: YO7_A66] #1225614
07/27/12 05:34 PM
07/27/12 05:34 PM
N.E. Ohio
N.E. Ohio
Thanks,once I understood the pattern of the changes it started getting easier.
Going to check fuel mileage soon. Got 10.5mpg originally.
Re: WideBand 02 Results [Re: 6bblFLASH] #1225615
07/27/12 07:07 PM
07/27/12 07:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So what exactly did you tweek in the carb to dial in the cruise?
Re: WideBand 02 Results [Re: Thumperdart] #1225616
07/28/12 01:05 AM
07/28/12 01:05 AM
N.E. Ohio
N.E. Ohio
As delivered it had .070 AFR`s and .040? IFR`s
Tried lots of combos and basically realized that if the idle circuit is maxed-out at idle,it can`t get much richer at cruise. Tried small changes to both IFR`s and AFR`s till it almost isn`t enough fuel to idle cold.Also lowered the primary float to just below the hole. That go me the 13.5 cruise.
I expect mileage to be 13mpg or so. Got 10.5 @11.7/12.2 AFR,,,,,11.98 @ 12.5/7 AFR. Hope 13.5 yeilds a 13+.
Re: WideBand 02 Results [Re: 6bblFLASH] #1225617
07/28/12 02:09 AM
07/28/12 02:09 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
When I went from 71 to 73 idle bleeds, it was definately too lean and was real slow to idle back down so I`ll try tweeking the mixture screws to see if that will stableize it. Good little tuning tool to get us close on our tune-up then fine tune at the track...........
