mig over tig
#1225245
05/01/12 04:26 AM
05/01/12 04:26 AM
Posts: 2,449 nc
earthmover
nc
Re: mig over tig
[Re: earthmover]
#1225247
05/01/12 09:10 AM
05/01/12 09:10 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Well if you dont own a tig welder, mig it with mild steel... if you want to loose weight use moly tubing but then you would have to tig it
Re: mig over tig
[Re: RADAMX]
#1225249
05/01/12 10:13 AM
05/01/12 10:13 AM
Posts: 11,702 W. Kentucky
justinp61
W. Kentucky
It takes practice to tig like the pros. I have both and if I need to do a good weld I still mig because I am better with it . I have not mastered the tig yet .I can tell you fit is everything with a tig .If there is any gap it is not good enough. Owned my tig (Miller 250) for awhile now mostly use it for aluminum. I may have to take a tig class just to get it figured out.
I'm in the same boat, I have a Miller Syncrowave 250 DX and need to practice, a lot.
Mig welding mild steel is fine, there a lot of fast mild steel cars that are mig welded.
Re: mig over tig
[Re: RADAMX]
#1225250
05/01/12 01:27 PM
05/01/12 01:27 PM
Posts: 5,875 communist bloc of new jersey
jamesc
so there's three guys here (myself included) that have a great welder (miller 250) that's a better machine than they are welder. i sure wish i could weld like i REALLY want to, the "pros" lay down some awesome beads. of all the mechanical skills this is my weakest vs how i would like to be at it. i kept looking around for a class at one of the local trade schools but didn't really find anything. from my little experience practice has a lot to do with it. i don't weld often but when i do the more i weld the better i get. problem is when i don't weld for a while i have to start all over learning again.
i do personally know a chassis builder that can weld as good as anyone i've ever seen and i know he would help me but i'm in jersey and he's in ca. it would really be nice to have someone show me what i'm doing wrong, i love the appearance of a quality tig weld.
as for the OP mild is allowed to be migged so if you feel you can do a better job with your skills than go that route. that said tig is the better weld when properly done.
Re: mig over tig
[Re: RobX4406]
#1225252
05/01/12 01:41 PM
05/01/12 01:41 PM
jamesc
Get out there and practice...
well if you did that it's guys like you i hate, man i wish i could weld like that. i'd weld things that didn't even need it. what bugs me most right now is that i'm at a stage in one of my projects that's needs a bunch of welding and i've been putting it off cause of that. i guess i really do need to just start melting stuff. i can usually put down a barely acceptable bead when in a good position but that tubing just kills me, that and having to deal with the pedal which can be a challenge. i was thinking about getting a fingertip control but seems most guys that do this often say it's not a real help
Re: mig over tig
[Re: earthmover]
#1225254
05/01/12 01:58 PM
05/01/12 01:58 PM
Posts: 7,506 Az
Crizila
Az
Mig welded a 10 point mild steel cage in my 300 this Janurary. Might not be as pretty as some professionally done tig stuff, but just as strong if done right - and for a fraction of the cost of having one done.
Fastest 300
Re: mig over tig
[Re: Crizila]
#1225255
05/01/12 02:37 PM
05/01/12 02:37 PM
Posts: 2,074 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Years ago, before I could weld or owned a welder, I borrowed a small mig welder (110 volt) and fit some stuff I needed welded and tacked it together. After I got it stuck together, I had a friend of a friends cousins buddy come over to my garage one night and welded everything up that I had tacked. (This guy welded for a living). After that I got some more done and had him over again. The down side is that it took a while to get it done, but the up side was he did it cheap. (took him with me to the races a few times and fed him good, he was happy) Still some of the nicest welds on my car today. And yes, like anything else, to make nice welds you have to stay in practice. Don't mean you forget how to weld, but if you want it to look nice, practice first.
Brian Dunnigan
Re: mig over tig
[Re: Crizila]
#1225256
05/01/12 02:43 PM
05/01/12 02:43 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
A foot pedal is fine if you sit or stand in one spot,if not just set it with the dial. If you are using mild steel a mig is fine,don't let anyone tell you you can't make a nice looking weld with a mig.If using CM then a tig is a must.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: mig over tig
[Re: jamesc]
#1225257
05/01/12 03:33 PM
05/01/12 03:33 PM
MR_P_BODY
I can come pretty close to those beads but it takes time(slow) to get them to look like that... I tend to weld a bit faster... I've lost some of the nack to do the real nice beads... you need to do it all the time and since I retired I dont do it alot but I just finished up a chassis.... the thing with tig welding is to be comfortable... if you arent the bead wont look nice... I need to practice more on alum to get the nice beads and I use to love doing alum
Re: mig over tig
[Re: MR_P_BODY]
#1225259
05/01/12 03:50 PM
05/01/12 03:50 PM
Posts: 12,032 Finally a HUSKER again
Moparnut426
Practice, practice, practice....
I dont tig every day, but I NEVER run a bead on anything unless I take a few practice passes, and before I start a bead on the good work Im welding up, ill make a practice sweep over where Im gonna weld to make sure im not gonna get halfway through a sweet bead, and bump into a cross piece, or move out of comfort.
With tig welding it takes more to get the feed, speed, and heat all timmed just right, and with aluminum the longer the weld the less amperage you will need due to the speed heat transfers throught he auminum, so its nice to have a foot feed "throttle" for the amperage.
Stainless, and mild steel arent as prone to this happening.
Kasey
Re: mig over tig
[Re: earthmover]
#1225262
05/01/12 08:43 PM
05/01/12 08:43 PM
Posts: 6,034 Salem
Grizzly
Moparts Proctologist
Salem
There is an old-school alternative that is really affordable to get into and is a good practice for stepping up to a TIG: Oxy-Acetylene gas-welding. With a correct-sized tip you can direct the heat wherever you want to the surfaces you are bonding. Build your pool, heat the rod and get moving. Entirely possible to make welds like those in the photos above. It's well-suited to what you want to do. It's getting to be a bit of a lost art, but I enjoy picking up the torch every now and then. A MIG is a production machine, whereas the TIG or Oxy/Acetylene is an art.
Mo' Farts
Moderated by "tbagger".
