How can I pressure test the A/C system?
#1225106
04/30/12 11:53 PM
04/30/12 11:53 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I don't have an A/C machine at home but I do have a set of gauges. How can I pressure test the A/C system at home without buying lots of cans of A/C dye?
I was playing with the Imperial tonight. I flushed the heater core with water and it leaks. Yay. Finding another one will be fun. Just for giggles, I pulled the cap off the A/C schrader valve. There was a bit of residual pressure in the system. Not much mind you, but there was positive pressure. I spun the clutch by hand and the compressor seems to turn smoothly. I can't feel any appreciable resistance but there's hardly any pressure in the system. I fired up the engine and jumped the compressor clutch. It kicked in without any bad sounds. There was no change in idle speed but I wouldn't expect that after turning it by hand.
I'd like to push my dumb luck and see if the mechanical bits of the system will work.
What's the best way to pressure test it at home?
Re: How can I pressure test the A/C system?
[Re: feets]
#1225107
05/01/12 12:04 AM
05/01/12 12:04 AM
Posts: 905 SD
zrxkawboy
SD
The best way I know of is to pull a vacuum and see if it holds. Do you have access to a vacuum pump?
As far as the heater core, when mine started leaking in my 57 Plymouth, I had it re-cored locally.
It's Swifty! Swifty, you toad sucker!
[Re: feets]
#1225108
05/01/12 12:14 AM
05/01/12 12:14 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I have never seen an AC system pressure tested. Instead they are evacuated using a vacuum pump. I bought a cheap one from harbor freight that operates off of a shop air compressor. You such all the air out and make sure it holds the vacuum. Remember r12 freon is very very expensive, you may want to retrofit to r134a, but the oils used in r12 and r134a are not compatible so while the system is empty you may want to take the opportunity to flush it and get it ready for the r134a.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: zrxkawboy]
#1225109
05/01/12 12:16 AM
05/01/12 12:16 AM
Posts: 9,316 SoCal
68HemiB
SoCal
Another vote for a vac test (although a system that will hold vacuum isn't necessarily guaranteed to hold pressure).
At the risk of stating the obvious, you don't have to spend the $$ on R-12 to see if holds pressure. Armed with an adapter, you can use much cheaper -134a for pressure testing. Truth be told, you can even RUN R-134a in your system...
Down to just a blue car now.
[Re: 68HemiB]
#1225110
05/01/12 12:17 AM
05/01/12 12:17 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Another vote for a vac test...
If only he had someone local to borrow a vac pump from....
[Re: finadk]
#1225111
05/01/12 12:21 AM
05/01/12 12:21 AM
feets
Senior Management
Senior Management
Irving, TX
I know about vacuum testing the systems. I've done that on my truck and Concorde. I was hoping to pressure test the system so I could find any leaks without going through a dozen cans of Freeze 12 with dye.
I'd have more time to mess with it at home during the week. I'm the late guy at work and only have an hour or so after work before they want to lock the facility down for the night.
[Re: OzHemi]
#1225113
05/01/12 12:23 AM
05/01/12 12:23 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Vacuum isn't very accurate esp with the HF pump. Dry nitrogen is the way to test with a true pressure of what the system would run. 134 is great if you want cancer...
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: herkamer]
#1225116
05/01/12 02:31 AM
05/01/12 02:31 AM
Posts: 1,572 Jacksonville Florida
elitecustombody
Am I missing something? As long as OP has good gauges that's all that matters if he can manage to pull vacuum.
BTW,OP , the HF little red plastic box/pump works just fine for quick vacuum ,as long as you have air supply to operate it. I use it all the time.
[Re: herkamer]
#1225118
05/01/12 07:05 AM
05/01/12 07:05 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Ive done AC since the 80s.You pull a vacuum and let it set.See if it drops.Then you add a small charge and use either a black light or leak detector.I prefer the light as the dye is easy to see.If you have a leak you usually reclaim the 134 you put in.We did have a 12 machine at work but it hadnt been used in 5 years.I might have a heater core.I cant remember if I scraped the heater setups from my 70 Imps.Rocky
Chrysler Firepower
[Re: GoodysGotaCuda]
#1225120
05/01/12 02:12 PM
05/01/12 02:12 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
when you turned it over by hand did you have the power on and the clutch was engaged or was it just freewheeling the bearing? . if the system is low you cant energize the clutch therefor lock the clutch/pully and be able to turn the pump.
I am truckless..
#1225121
05/01/12 02:19 PM
05/01/12 02:19 PM
Challenger 1
Cincinnati, Ohio
Those sniffers are very senitive and the tip can be ruined/tainted real easy. Never stick it into the hoses or touch anything with them. If freon get's on it most times they need to be replaced, the sniffer tips. AC sucks to work on without a recovery machine. I have been busy with AC repairs here lately. I am working on AC as I type this. Most of my trucks lose about a 1/2 pound per year. I just pull it all out, pull a vacuum and recharge with 2.2 pounds and reset the dash light. Good for another year until I find it 1/2 pound low next spring. Never any leakage visable around any connections or hoses.
[Re: finadk]
#2807133
08/10/20 01:09 AM
08/10/20 01:09 AM
Posts: 28,621 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I have never seen an AC system pressure tested. Instead they are evacuated using a vacuum pump. I bought a cheap one from harbor freight that operates off of a shop air compressor. You such all the air out and make sure it holds the vacuum. Remember r12 freon is very very expensive, you may want to retrofit to r134a, but the oils used in r12 and r134a are not compatible so while the system is empty you may want to take the opportunity to flush it and get it ready for the r134a. That is what j do the Red Cheap HF Box. My buddy who does home A/C has a,pump and does same thing. Sucks the system d own and leaves goes on another call and returns to see if it is ok to fill or not.
