Re: My turn for a wideband O2 tuning thread
[Re: herkamer]
#1224258
04/30/12 10:12 PM
04/30/12 10:12 PM
Posts: 3,890 Oregon
hooziewhatsit
Going in the right direction!
Since you have a way to datalog manifold vacuum, check to see where the problem is. That will let you know where the enrichment is coming in, and where the springs needs to be.
Alrighty, looking at the log, assUme-ing I got my voltage-to-vacuum conversion correct (pretty sure it is), at 'light' throttle, it drops to ~5"hg with high 11s for AFRs. As speed increases and I pass through ~7"hg, AFRs shoot up to high 15s & low 16s. Which makes sense with the 7" springs in.
Just went for another drive with the Orange springs in. At light accel the AFRs stay high. I do think my pump shot either needs to be bigger, or longer, as it's spiking to 18ish just off idle, right when I feel a hesitation now
Looking at another light acceleration; vacuum is 5.5ish with AFRs in the 15s. Right when I give just a little more throttle and it drops below 5" vacuum, AFRs drop to the 14s.
I've been debating whipping out a circuit board for this manifold vacuum sensor and selling it. Not sure if anyone else would find it handy though, as it requires the LMA-2 RPM adapter to work
Attached is a light acceleration pass with the Orange springs, and accelerator pump in the 3rd hole. (For some reason it logs the tach as being really jumpy. Probably the points bouncing )
[Re: hooziewhatsit]
#1224259
04/30/12 10:13 PM
04/30/12 10:13 PM
Posts: 3,890 Oregon
hooziewhatsit
And here's a WOT pass, right after the previous light acceleration pass.
[Re: hooziewhatsit]
#1224260
04/30/12 10:57 PM
04/30/12 10:57 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Try the middle hole for pump shot, and double check the measurement from top of stem to air horn. Definitely going lean on the tip in. It would really be sweet to see throttle position, that definitely shows a bit of information. You might need to increase the size of the nozzle (and amount of pump shot accordingly) to keep it from leaning out. As the book says, go for the minimum pump shot to get you accelerating correctly.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: herkamer]
#1224261
05/01/12 11:45 AM
05/01/12 11:45 AM
Posts: 3,890 Oregon
hooziewhatsit
For the accelerator pump, if the middle hole doesn't get rid of the lean spot, I may need to go to a smaller squirter to lengthen the duration of the shot, right?
The only thing I've seen in regards to measuring the accel pump (on an Edelbrock vs Carter) is someone mentioning to make sure at full throttle the pump is all the way down, and to bend the arm to make that adjustment. Which I guess does make sense to me; make sure you have maximum travel and that it doesn't pump air at the top of the stroke.
I had thought about how nice it would be to have throttle position, but have yet to find a good way to connect a potentiometer to the throttle shaft. Instead I came up with the vacuum idea, which has actually been quite useful as well.
As for the cruise AFR; am I ok as long as I don't feel any surging or bucking? I can richen that up a little, but figure if it's running fine and I won't burn a hole in the pistons... might as well stay where it is and enjoy the (mild) mileage gains.
[Re: hooziewhatsit]
#1224262
05/01/12 12:17 PM
05/01/12 12:17 PM
herkamer
Lakewood, Colorado
If moving to the middle or even back to the top hole doesn't correct the lean spot, you might need to increase the nozzle size so it discharges fuel faster. It really depends where the lean spot is and how long it lasts. If it feels like a 2 second hesitation, then a smaller nozzle would cure it by lengthening the shot. Full throttle bog would probably require more fuel faster, so bigger nozzle and higher up on the hole. To start, I would put it in the middle hole, and check to see if the pump shaft top is 13/32 above the air horn so you know you are starting at factory spec and continue from there.
Cruise AFR looks ok. I run 15-15.5 and it doesn't surge in my W350 with TBI. I notice about 17 or so is when it feels like it's going to fall on it's face and starts bucking a bit.
[Re: Dunnuck Racing]
#1224264
05/01/12 02:11 PM
05/01/12 02:11 PM
Posts: 3,890 Oregon
hooziewhatsit
If you are goig to be pulling that trailer,I would richen up the part throttle mixture. You will lose torque a lot faster on the lean side of stoich. Add in the fact that you are tuning without a load right now,you will have more throttle opening(less vacuum) while pulling your trailer. Just hate to see you go too lean and hurt something. Keith
That makes sense. I also (think I) got some light surging at 35mph through town earlier. So, I'll go another step or two richer on the cruise side and see what happens. The trailer itself is ~3500#, and add a couple 1k# horses...
After looking at todays logs, I may need a longer pump shot as well. WOT seems to be fine, but at slow acceleration AFRs tend to jump to 18ish for ~1s, then go back to normal.
Thanks again for all the help
[Re: hooziewhatsit]
#1224265
05/05/12 10:58 PM
05/05/12 10:58 PM
Posts: 3,890 Oregon
hooziewhatsit
Earlier today I put 70-52 rods in (one step richer on cruise). Much much better overall. I still have a lean spike off idle at low acceleration that I can barely feel. I'm thinking a smaller nozzle will extend the duration of the shot, and should probably cover that? I've also noticed at part throttle in enrichment (under 5"hg), the AFRs are mid to high 12s. At WOT, the AFRs are in the mid 13s. I think this is saying it could use one step richer jets on the secondary side, right? I think I'm nearly to the point where it will 'just drive'
[Re: hooziewhatsit]
#1224266
05/05/12 11:17 PM
05/05/12 11:17 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
Sure sounds like you are getting it dialed in! I should also mention that with oxygenated fuels that are at most places at least in this area,I have found that just about everything likes to be a little bit richer than what you would think. The stoich numbers are different for different fuels so you have to adjust accordingly. I know some guys are trying to lean everything down for mileage these days but fuel qualities vary and it can be frustrating when you fill up out of town and get some fuel that makes you get lean surging and pinging all the way home pulling a trailer. I would fatten it up a tad more. Keith
#1224267
06/10/12 04:50 PM
06/10/12 04:50 PM
Posts: 3,890 Oregon
hooziewhatsit
So that stumble I've been chasing Finally got time to hook up with Jeremiah yesterday and take him for a ride to see what he thought. The off idle stumble I thought was fuel related, he thought was ignition related. He had the electronic distributor and a spare box & harness, so a few hours later, the points distributor was out, and it was running. Wow, it's never run this well before All of the off-idle hesitation/stumbles are gone. So NOW I can finally get to tuning it Currently running: mid to high 13s at cruise (55mph, ~12"hg) mid-high 11s at part throttle enrichment (I think this is still a little rich?) mid 12s at WOT If I floor it from a stop, I can see the AFRs go to mid 11s, then to 14ish (over the course of a second), then it evens out in the mid 12s. I think I still need a smaller squirter to lengthen the pump shot. Otherwise I don't feel any stumbles off the line. I can only see it in the log. So, big thanks to Jeremiah for giving me the electronic disty & Orange box and fixing the issues I've been chasing for a few years now
[Re: hooziewhatsit]
#1224269
06/10/12 09:03 PM
06/10/12 09:03 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
Your cruising a/f might be a tad rich but you won't know until you try. I would suggest low to mid 14's for cruise. Your mid 12's sound good for WOT and this should be your richest a/f reading. Your 11 readings for enrichment are too rich. I would suggest making your part throttle enrichment a/f numbers be in between your mid 12's for WOT and 14's for cruise. The enrichment numbers may vary pending on the seat of the pants feel of the driver. My cruise numbers from 30-70 are currently at 13.6 to 14.6. My enrichment for light throttle is 13.8 to 14.2 and my WOT is 12.8 to 13.0. Each motor combo will be different, but over the last year of driving with an a/f sensor, the above numbers are what my current combo and my butt-ometer feel are good driving numbers for my car. Hope this helps.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1224270
06/20/12 09:03 PM
06/20/12 09:03 PM
Posts: 3,890 Oregon
hooziewhatsit
Got some more testing done. Current set up is: 95 mains 101 secondaries 68/52 rods orange springs Cruise is mid 14s Part throttle enrichment is low to mid 12s WOT is 14ish (Remember, I'm at 4000' here) Other than the weird WOT numbers, I'm pretty happy with the driveability and overall tune. I guess part throttle enrichment could probably be a little leaner. I think once I get everything dialed in, I'll keep a second set of rods that are a tad bit richer for the rare times I do have to tow something. 98% of my driving is highway just moving things around.
[Re: hooziewhatsit]
#1224271
06/21/12 04:51 PM
06/21/12 04:51 PM
YO7_A66
Indiana
Your definitely making the correct changes. Your numbers are falling right into place. I would suggest that you tune the part throttle until it "feels good". I played with mine from low 14's to low 13's and it felt better/crisper in the upper 13's to 14.0. Your low to mid 12's (part throttle) is where you might end up for a WOT reading, so once you lean the part throttle out your WOT will go even leaner, so be carefull.
